Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan chain saw after carb rebuild.
I rebuilt the walbro carb on my chain saw. It starts and runs fine but tends to die at high rpm under load. You have to feather it to keep it running. (move the throttle in and out) Once it dies it will not start until cool. I tried adjusting the high mix screw. Does not seem to make much difference. Start at 1 1/8 turn all the way to 3 1/2 turns. My weed eater does the exact same thing.
  • 1 more comment
  • donaldly Feb 04, 2009
    Yes there is two. High mix and low idle. I have adjusted both per above. Idle is fine for the most part.
  • Anonymous Mar 24, 2014
    I can't get it up in high rpms just dies, when given gas and it will only run with the throttle About 1/10 open but once I try to move any adjustment hi or lo it just dies.
  • Anonymous Mar 31, 2014
    wont keep running after chain is engaged
    Sergeant:
    Champion:
  • 373 Answers
Is thereadjustment somewhere on the saw
I think there is 2 .
Posted on Feb 03, 2009
The small saw serial #1J295L669 starts O.K. and runs for about a minute, but then dies on me. there is a high and low adjustment screws;however the cover over the carb. seems to have an effect before and...
Most of carburetor has three buttons to adjust. L (low), H (high) for fuel injection at low and high speeds. There is also a minimum (the chain must be stationary if it is well tuned). The chainsaw is set at low rpm throttle with screws ( L ), and its vivacity is set at high speeds ( H screw ). In the beginning is good put both to set at 1.5 turns from full closure. And then, if the chainsaw starts, you can adjust a carburetor work. Careful with adjusting with H due to high speed.
Sep 06, 2011 | Poulan Garden
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 42 cc 18" poulan chain saw I cant get it to idle its either all or nothing. I cant start if the chain break is on and when it starts the chain runs. It dies under stress and then is a...
If the chain runs at idle, or tries to turn when cranking the saw, then there is an issue with either the clutch drum bearing or the clutch spring has become weak, to get to both of these components you need special tools, the tool to remove the clutch is part no. 530031112, and the tool to adjust the carb screws is part no. 530035560, the L screw will adjust from idle to half throttle including acceleration, the H screw will adjust the full engine speed
Apr 03, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I rebuilt this carb and it is geeting way to much fuel do you have a parts brake down and assembly instructions? The carb # is WT324
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to other brands as well. Hope this helps!
Oct 16, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Screw mixture settings
1 1/2 turns open. Start unit then fine tune from there.
Apr 11, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Mar 25, 2009 | Poulan ES350 16" Chain Saw
Poulan Wild Thing and Wood Shark Saws try to run, but stall down.
They could be sucking gas from the base gasket, head gasket or the bearings. Also, Check your flywheel very wheel and your armuter, if either are rusty then they need some sand paper to help create spark. There are rebuild kits and they are cheap. I always tell my customers to fix there older machines cause the new ones are **** and they leak everywhere and if anything brakes they are REALLY expensive to repair. You can get a rebuild kit whole machine for about 65 dollars
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw carb tune
starts with the choke then shuts down when you shut off the choke. what is the settings for the carb
Jul 10, 2008 | Electrical Supplies
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
836 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
