Question about Durabrand Portable DVD
I need to replace the power cord between units....
I need to replace the power cord that bridges between the two units. Does anybody know where I can get one?
  • silvajl3 Mar 19, 2009
    The end of one connecter has been damaged and doesn't get a good connection. I have also been trying to find a replacement cord.
Go to www.1800customersupport.com, select your brand on the left side. Click DVD players and it is best to go through all the links to find the correct system. I have the same problem with my power cord and my unit falls under the portable DVD players.
Posted on Apr 12, 2009
    President:
  • 1,179 Answers
You could try cables2go.com. They sell just about every cable known to man. Hope this helps.
Posted on Feb 03, 2009
Replace Power Cord - Technics 1200 MK2
It's an ac cord. there is no positive and negative. the solid black side is "hot" and the ribbed or striped side is "neutral".
Apr 28, 2013 | Technics SL-1200MK2 Turntable
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
Hi. The Sportasrt T680 Treadmill shows Error 2_1. Does anybody know, what should I check in the AC Servo Driver? The IGBT bridge is okay. Any other? Thanks.
hi,
The primary reason for E2-1 is that the drive board detects IGBT over current signal
Check the folowing.
A. Re-start the unit.
B. Inspect whether the servo motor wires are connected properly to the motor.
C. Replace the drive board.
D. Inspect the servo motor windings for a break. If so
E. Replace the servo motor
Aug 28, 2011 | Exercise & Fitness
I need to convert my dryer from a 4-prong to a 3-prong power cord. I understand all steps of the installation except for the grounding wire. Since there are only three cords now I no longer have a...
On your cord, the outside leads are the hot leads, with each one carrying 120 volts. On a four wiire cord, the two inside lines are neutral and grounds. For a three wire cord to be used with four lugs, the middle wire connects to one of the middle lugs, and the inner lugs should be connected together, Normally, a drier comes with a bridging plate to connect the two lugs, and it is removed for a four wire cord, or left in place for a three wire cord. You can bridge the two terminals with a piece of substantial insulated wire. I have never tried to buy a bridging plate, but you might try Lowe's, etc. for one.
Best regards,
--W/D--
Jan 21, 2011 | Dryers
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
My subwoofer IC got burned because i accidentally plug it to a 220v power supply, mine is only 110v i want to know the IC# subwoofer.
Most likely what got burnt is the bridge rectifier in the power supply section of the electronic circuit. This usually takes the shape of either a single 4-legged IC, or a group of 4 rectifying diodes connected in a bridge configuration. If you disassemble the unit to which the power cord is attached & trace the circuit starting from the terminals of the power chord, you can easily identify it. You will need to replace the 4-legged IC or the 4 rectifying diodes.
You will also need to replace the fuse, since it is usually likely that it gets burnt if the unit is attached to 220V instead of 110V.
Nov 24, 2009 | Altec Lansing FX4021 Computer Speakers
I need a power supply cord for Ultra LCD30-500
if you have the power supply and all you need is the cord, it looks like the cord is the same as a cord for a computer power supply.
if that not right , reply will look somemore have a good day please remember to rate bama46, thanks
Aug 23, 2009 | Ultra LCD30-500 Television
THE COMPUTER IS NOT WOKING
Check the power cable/cord for continuity with your multimeter ok. Make sure also that the mains or power outlet is giving the right voltage. This is also done by the use of the multimeter - either analog or digital - any one at your disposal can do ok. if all work well, then the power supply unit should be removed from the system unit, connected directly with the power cord and then bridged. That is at the secondary output which connects to the system motheboard. Locate the power-on cable(normally green in colour) and bridge it with any black cable on the same row. The cooling fan at the back of the power unit should be rolling if the unit is ok. Good luck
Jun 03, 2009 | Compaq (243890-001) 250-Watt Power Supply
I recently received a really nice R600 Kenwood.
Hi Doug,
To my knowledge, the Kenwood R600 straight from the box runs only on AC power hence no DC jacks.
However, there is a DCK-1 accessory which is a DC cord kit for this receiver.
Alternately, the secondary output of the transformer is 14VAC which is feed to the bridge diode of the power supply on the PLL unit/board. With that in mind, it would then be OK to hardwire 13.8VDC right after the bridge diode and parallel to the big filter capacitor. It may be a good idea to put an inline reverse protection diode and a fuse. Of course any DC type of jack/plug combination/arrangement may also be used.
Additionally, you might be interested in a service manual for the Kenwood R600 which is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Kenwood...
WONT POWER ON when plugged into a known good power source
This is from the FAQ on a similar model (the 770). My guess is that it won't be much help, but who knows... : The machine is not receiving a power signal. Make sure the power cord is plugged securely to the power outlet. If a surge protector or an extension cord is being used, disconnect them and plug the fax machine's power cord directly to the power outlet. If the fax machine is still not receiving a power signal, try plugging the machine's power cord into a different outlet on another circuit breaker. Good luck
May 19, 2006 | Brother IntelliFAX 775 Plain Paper Thermal...
Durabrand Portable DVD Logo
103 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
