Question about E-Machines eMachines Desktop PC
My computer only starts that's all.
My e machines T2260 continually restarts but never displays the homepage, I no longer have the restore cd so any suggestions?
    Champion:
  • 203 Answers
Start in SAFE MODE and try to restore system at earlier stage. To start in SAFE MODE use F8     at the boot time. if that does not help you reinstal windows.
Posted on Feb 03, 2009
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
Restoring
go into the Bios and set it to boot from disk, restart and it will walk u through, as long as it's xp or vista. Once it loads it will give you the option to repair, and at that point it will ask for the restore disks
Mar 05, 2009 | E-Machines eMachines Desktop PC
Emachine W6409 will no longer turn on
Your hard drive is probably crashing or has crashed. You need to start your computer with an XP CD and try to use the repair function. You'll be able to tell if the hard drive is still working or not once you run the repair function. Let me know what happens or if you run into any problems.
Feb 20, 2009 | E-Machines W6409 (7234) PC Desktop
Removing partial install of 2nd os
You should be able to do a SYSTEM RESTORE to a point before the XP Pro installation.
Start the machine and start tapping the F8 key until the boot menu is displayed. Use the arrow keys to highlight SAFE MODE and press enter. If you are given a menu to choose which Windows to boot into, choose the Home edition. Windows will load with the minimum drivers. Your screen display will be 640 X 480 and the icons will be large. You will eventually see a window advising you that you are in safe mode, click OK or NO. Click NO. That should open The System Restore function. Choose to restore the system to an earlier date. A calendar with be displayed. The BOLD dates are the ones that you can restore to. Choose a date that was before the date you tried to install XP Pro. Follow the prompts and the restore process will run and reboot your computer. Following the reboot, the installation will complete and Windows will open.
If you have installed a service packs or updates after the restore date you will need to install them again.
Good Luck! and please let me know how this works out for you.
Jan 16, 2009 | Computers & Internet
Factory setting restore
If you have a Cd Rom called a Recovery Disk that usually comes with the computer. You can reformat the computer to it's original configurations. You will lose all data. It will be as if you took it right out of the box. Or on some computers you can do a Recovery only withour reformatting the PC. you will have to reinstall all updates , programs, etc. you turn off the computer and install the disc then you restart the computer. The disk will give you the option to Recover Only or Recover and Format.
Dec 13, 2008 | E-Machines T2042 PC Desktop
Packard bell restore new Hdu
From parkard bell suppport website Quote
"Step 4 - Re-installing your software
Call the help desk and ask them to guide you through the
ExtHS process.
Please have your Recovery CDs to hand when you call
the Easy Repair line.
Once you have completed the ExtHS process you will
need to re-install Windows and the other software supplied
with your Packard Bell computer. To do this follow the
steps below:
1. Disconnect all peripheral devices (web cam, printer,
scanner, broadband modem etc.).
2. Insert the Packard Bell Master CD 1 / DVD in the top
CD / DVD drive and restart your computer.
3. The CD will load and display the following message:
Please refer to the section headed Packard Bell
Recovery Program in your user’s guide for instructions
on this utility. Press OK if you want to continue
or Cancel to return to DOS.
4. Press the letter O on your keyboard to continue.
5. You will see a menu with options. Please select option 1
“Standard System Restore”
by pressing the 1 key on
your keyboard.
6. A warning message about data loss will be displayed.
Press the letter O to continue.
7. The process will take around 40 minutes. Once this is
done you will need to restart your PC. Remove the CDs
and store them in a safe place.
8. If there was a Software Library DVD supplied with your
PC you can use this to install the extra software that was
supplied with your computer. Insert this into the drive
and follow the onscreen instructions.
9. Finally, you will need to install any additional devices
(web cam, printer, etc.) and software by following the
instructions supplied with them."
Jun 09, 2008 | Packard Bell Computers & Internet
HP Desktop keeps rebooting itself
Hi Julie, the boot order is not correct. You need to change the order to boot to you're cdrom first than to you're hard disk drive.
To change that order go to the boot section of you're bios. Move to select you're cdrom & press enter on the keyboard & a list will open. You cam move devices up & down by pressing the + or - keys. Once you have corrected the boot order save & exit.
As the pc begins to start back up, press the F8 key every 2 seconds. A window will open, look for ( Disable automatic restart on system failure ). Choose the option. Windows should continue to load windows. If you see any error messages write them down & post them here.
If windows does not load continue following as mentioned below.
Check if the PC continues to reboot itself. If it continues to do so than you're windows boot files may be corrupted or worse. Load you're restore cd or you're windows cd into you're cdrom drive & restart you're PC. You should see. to load the cd press any key... (Press the space bar). You're cd will start to load. If you're using windows or the restore cd follow the on screen instruction to reinstall windows (ONLY). Doing a reinstall will not earse you're personall data. Do not format you're drive, (Yet). Finish installing windows. The PC will restart once or twice & you will see ( to load from CD press any key... ) Do nothing, windows will continue installing. When finished run windows update till there are no more updated. Some programs will need to be reinstalled, like printer software.
Post back if you need more help or have questions.
Good Luck Julie!
Mike
How to vote you're expert & repost questions.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 13, 2008 | Computers & Internet
Kika633@yahoo .com
you need to reinstall windows, put in floppy boot up disk set the cd to run have your windows cd in tipe d: install
Dec 24, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
53 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
