Question about RCA P52937 52" Rear Projection Television
Where is the eye for the remote on the TV????
Also, the buttons don't work on the front of the TV. Only the power button works. I need an anwer to this as soon as possible.
Thanks.
    Scholar:
  • 150 Answers
Hi, remote sensor is located behind the front screen, if the remote doesn`t work as well (you didn`t say so I`m assuming it doesn`t) then you either have bad tact switches on the control board (the buttons on the front of the set) or the 5 volt line to the control board is missing, video-tek
Posted on Feb 05, 2009
Tv power (redlight will come on powering the TV then back off
If the model here listed is correct it may be the actual power switch--it like all the front controls is a tiny micro switch--only supposed to work when pressed but can and does fail in this way--
How to prove/disprove this?
Someone needs to remove the front keyboard and unsolder that 2 pin switch---remote will with the board back still turn set on.
If it works that way either just use the remote or search for the keyboard and replace if can find one.
Only other issue possible is the microprocessor in the set could be bad and we do not want that-----both the front buttons on set and the remote go to the same place inside the set but the keyboard has priority over the remote.
If power button bad, button on the remote will not stop or correct this.
SD TECH
Apr 22, 2012 | Hitachi 53SWX10B 53" Rear Projection...
We have a red light flashing on the front of the tv.It shut off and we don't know how to turn it back on.
A red flahing light is sometimes a Standby Mode. Does the power button on the remote turn it on.Sometimes the remote has multi funtions and you need to select TV for it to work.Try using the Power Button on the TV.Good Luck.
Jul 29, 2011 | Toshiba 44NHM84 TV
My Mitsubishi projection TV will not produce audio or video
Two things are involved to cause that problem, tv remote control and remote sensor in tv.
Upon verification of remote working, it would be confirm that remote sensor in tv is defective and need to be replaced.
Remote control sends infra red light signal to tv and we can not see that light with naked-eye, so need digital camera or cell phone camera to see it by watching remote front through camera, press any keys on remote, if you see infra red light is blinking in remote front that means remote is working and remote sensor in tv will be replaced.
If no light blinking on pressing remote buttons confirm that this remote is defective and buy new remote.
Let me know if you have additional question.
Thanks.
May 31, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tv blinks out when front buttons are pushed. model#ws-65511
If the TV is turning on and working regularly, but power button does not shut down and buttons on TV do not work, then it is a faulty touch control (button) board on TV.
If instead the TV does not even turn on, then tv is on protection mode, in that case it can be any internal fault.
If instead the problem is with remote buttons, then it is either a faulty remote or a faulty IR sensor.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Optical eye
LOL, optical eye? OK, that’s the problem, there is no such part. However, you did not say if any other buttons were working on your remote, ie ch up and down, input, power on and off, ect. If so, it will not be your remote. If you the volume is not working, check you menu setup, under the audio setup.
If no remote functions are work, you can try the inferred Receiver. Its only about 20.00 to replace and can be found at most part stores. Cheaper if you change only the IR block itself.
TV tech
Jul 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
27 in samsung tv
TRY UNPLUGGING THE T.V. FOR TEN MINUTES. THE TRY THE BUTTON ON THE FRONT OF THE SET. YOU SHOULD BE ABLE TO GET AN ORIGINAL REMOTE FOR AROUND $40 .
DON.
Jun 12, 2008 | Samsung HCL4715W 47" Rear Projection...
Hitachi 51SWX20B projection TV has no picture or sound
first lets check the remote to see if its working , with a digital camera facing the front end of remote (where THE EYE is) look thru the camera screen while pressing any button from remote , you should be able to see FLASHING LIGHT coming from the remote. SECOND about your TV , better off to have unit check by an authorized tech . hope this helps
Apr 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Won't power up
This model has had problems with the keyboard buttons on the front panel,causing them not to work and canceling out the remote operation. To verify this,you need to remove the front panel so you can access the connector on the keyboard pc board and unplug the connector.After doing this,see if the remote control is able to turn on the tv (wait for it to power up because with the connector off, the green power light will be disconnected and will not light up when the tv is on) If the tv works, than you will need to change the ten individual switches on the board - part# 432P089010 (or just use the remote only)
Aug 21, 2007 | Mitsubishi WS-65611 65" Rear Projection...
RCA P52937 52" Rear Projection Television Logo
187 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
