Question about Motorola Mobility H710 Bluetooth Headset
Motorola h710 bluetooth will connect to phone but no audio
I can get my phone to say the bluetooth is connected but when I'm making or receiving calls or trying to talk, the bluetooth has no audio. The audio is coming through my phone only. The volume is turned on the bluetooth, and my phone is showing the icon that the bluetooth is connected and that sound should be coming through that not the phone!! So basically it's not working, but saying it's connected.
  • Anonymous Feb 04, 2009
    Ditto
  • Anonymous Apr 09, 2009
    i had the same problem, all i did was disable bluetooth (remove completely). Shut off your phone, and re pair it...and that will solve the issue.
I disabled the bluetooth from my phone. I then turned off my phone and rebooted it. Once the phone was turned back on, I paired it up with the bluetooth and then it worked. So disabling and removing everything and starting over worked.
Posted on Feb 04, 2009
    Problem Solver:
  • 14 Answers
If you need instructions on pairing the bluetooth back to your phone, check the video on www.HandBookLive.com under Electronics category. It has chapter on pairing with Motorola phone or Nokia phone. Other chapters go over regular button operations
Posted on Feb 17, 2009
  • 43 Answers
Reset your phone and device then connect it.
Posted on Mar 30, 2009
My Motorola H17 is paired with my HTC MyTouch 3G Slide. I turn on the Bluetooth and make a call. After I hang up from the call, when someone calls me, I receive the announcement through the BT that there's...
I have an HTC Desire, I find that if I answer on the phone by touching the phone screen's answer button it answers in the phone :( But if I push the button on the bluetooth to answer it answers in the bluetooth - very annoying but appears to be an HTC issue not motorola's
Feb 10, 2011 | Motorola Mobility H710 Bluetooth Headset
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
How to connect my motorola H710 bluetooth with my mobile
You must put it in pairing mode. If it has not been paired to other phones, just open its boom. After a while the indicator LED will be steady blue. Otherwise, if it has been previously paired to other devices, make sure the bluetooth radio of those devices are turned off. Then, open the boom and, as the headset won't find any devices already paired around, it will enter pairing mode automatically (again, indicated by the steady blue LED).
Once your headset is in pairing mode, make your phone's bluetooth application search for new devices. After a while, the H710 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, you can download it from this location;
Hope you are able to sort your problems out.
Cheers! Carlos
May 09, 2010 | Motorola Mobility H710 Bluetooth Headset
How do I sync my motorola H710 bluetooth with my Motorola Droid?
Here's the instruction manual for the H710:
Motorola H710 download instruction manual .pdf 2MB
You'll have to check your owners manual for your Droid, but it's probably under Settings > Connections > Bluetooth (Turn on) > Discover (Pairing code 0000)
Feb 04, 2010 | Motorola Mobility H710 Bluetooth Headset
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
Bluetooth H710 new..mic not working
Go in phone to setting then go to bluetooth and press it then select voice routing incoming hands-free
Aug 25, 2009 | Motorola Mobility H710 Bluetooth Headset
H710 won't go into pairing mode
sounds like its already connected to the iphone but it won't establish them. Delete the pairing from the phone then repeat the process.
Jul 27, 2009 | Motorola Mobility H710 Bluetooth Headset
How do I add a 2nd phone to motorola bluetooth headset h710?
after you connect one phone. go into phone settings and turn off bluetooth. go to second phone open bluetooth options. not put your h710 into pairing mode. once paired, go back to original phone, turn bluetooth setting back on, and both devices are now paired.
Jul 03, 2009 | Motorola Mobility H710 Bluetooth Headset
I hear the person clearly, they cannot hear me.
I recently had this same problem with my Motorola H710 Bluetooth & my Samsung SGH-A737. I could hear the people on my Bluetooth, and they couldn't hear me. It wasn't muted. I tried turning both the phone & the bluetooth off, then back on, first one, then the other, then vice versa; nothing worked.
Finally I deleted the H710 from my phone & reinstalled it. This fixed the problem.
To do this, navigate your phone's menu looking for the Bluetooth/Connections portion (every phone is different); select the bluetooth, then delete it from your phone.
To reinstall it, turn the bluetooth off. Then go back to your phone's menu and look for the equivalent of "Search For New Devices"; then, turn on the bluetooth. When your phone finds it, select it. The phone will ask you to input the pin. If it's the Motorola H710, the default pin should be four zeroes: "0000". I have heard this is the same for other Motorola's as well, but I can't say for sure. If you have another brand of bluetooth, either get out the manual and/or box (which should have the pin in it somewhere), or else get online and Google the model number and the word "pin"; you'll probably find it.
After I reinstalled it, it worked like a charm.
Apr 11, 2009 | Motorola Mobility H710 Bluetooth Headset
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility H710 Bluetooth Headset Logo
1,324 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
