Question about JVC KD-G230 CD Player
Radio stay on after car turn off
I have the radio for 1 year now and now the radio stay on after the car as been turn off
  • 72 Answers
Hi this is tech crazy
The solution to the problem you mentioned is as follows
just sounds like your ignition live to radio is actually permanant live.
Pull radio out and swap red and yellow over see if it helps. Is it an after market radio? If so this is probably the cause.
Hope this helps you a lot
Please do rate me on the above said solution
Posted on Feb 03, 2009
MY RADIO STAYS ON WHEN I REMOVE THE KEY and close the door
radio stays on after removing key from ignition - Car Talk
community.cartalk.com/.../radio-stays-on-after-removing-key-from-ignit...
Mar 4, 2012 - this just started today and when i turned off my car and removed the keyfrom the ignition, the radio stayed on.
04 F150 - Radio stays on after key removed & door open ...
www.f150online.com/.../323659-04-f150-radio-stays-after-key-removed...
Mar 2, 2008 - You know how you can take the key out of the ignition (after turning off), and radio continues until you open the door? Well, yesterday I opened ... More results from www.f150online.com
Oct 22, 2015 | Chevrolet Astro Cars & Trucks
Radio will stay on after I turn off my truck.
This sounds like an ignition switch problem.
The accessory is staying on after it should be off.
Jan 07, 2014 | Chevrolet S 10 Cars & Trucks
I have a problem with my honda civic years 2006...i need a code for my radio please help me
Hi the radio code is different for every car. If you go to the honda dealer they will ask you for proof
of ownership and then supply you with the code for your car ( usually a small fee )
I hope this will help you.
John ( South Wales UK )
Jul 05, 2011 | 2006 Honda Civic Hybrid
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
2003 Altima radio stays on after removing keys from ignition
It very well could be the BCM....only way to check it is to have a full featured scan tool, and check out the systems.
Sep 30, 2009 | 2003 Nissan Altima
Radio only plays for 1/2 second and then turns off.
Nevermind! My problem was fixed, I'm embarrassed to say, with new batteries. I had been told that the batteries in the radio were new when in fact they weren't. Thanks anyway.
-hwell97
May 17, 2009 | Sharper Image Travel Soother 20 Clock...
Mt heat wot work just replaced blower motor 1 month ago.
year of car unknown, but as far as the radio problem , check your fuses. Sounds like a blown BODY fuse. Check lighter fuses also
Feb 23, 2009 | 1994 Cadillac DeVille
Radio went out, door ajar light stays on lost manual for fuse box
Google the vehicle or you can ask the dealer what fuse is for a specific item or check each fuse 1 by 1.
Feb 06, 2018 | 2000 Mazda MPV
Radio will not stay charged. Battery replaced. Problem persits.
Does it look like the charger is working?
Batteries have a life of 1-5 years depending on how they are used. Check ebay for a new set of batteries.
Jan 14, 2009 | Maxon GMRS50 (16 Channels) 2-Way Radio
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
JVC KD-G230 CD Player Logo
212 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
