Question about Maytag MER6772 Gemini Electric Kitchen Range
Both ovens and clock are not working
F1-9 error appered and then went away. Nothing on control panel works? Any solution to this problem?
  • mackylopez Feb 20, 2009
    I have a Maytag -gimini gas stove. The elctronic panel has troubleshooting. It has a message SAb BATH. The related functions of the panel don't work-Ovens/clock/timer/etc.. Thanks you
    Problem Solver:
  • 14 Answers
F1 error usually signifies a broken touchpad or clock assembly or both. I would start with replacing the clock assembly as this is the most common cause of the F1 series error. If it does not resolve the issue you may have to replace the touch pad as well.
Good Luck,
Sai.
Posted on Feb 03, 2009
  • rich4027 May 09, 2011
    D-bag tech.....the Maytag Geminis have a Sabbath feature that allows them to operate for 72 hours continuously and then shut off. It's weird, I know. See the owners manual, available online, on how to reset your model. If you can't find manual for your exact model, try leavinving off the last two letter... (I have an MER6775 AAB - can't find that, but MER6775 A is there-- same model, differnt color I think.)
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
We have a Kenmore electric range mod. C970-440732. We have 5b or 56 error code on each element display control and 5ab error code on temp display on the the control panel. Nothing work except the clock. ...
Sorry to read about your problem, I hope this helps you out.
I am going to assume it a F5 error code, which means your have a oven control failure. and may need replacement. electronic oven control (also called EOC or clock).
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Kenmore Ovens
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | GE JSP26 Electric Kitchen Range
I can't find the model no. on my Hotpoint Ovan!
FFF Control Error, Failed EEPROM Replace Control
You can try a hard reset . turn off the power for 1 minute.. also you can check the connections to the control .. other then that you will have to repalce the control
Sep 29, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Error codes
Clock error it happens when the external clock goes out of sync with the internal clock nothing to worry about it should have went away on its own after about 30 seconds
Dec 06, 2007 | KitchenAid KEBC277 Electric Double Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
381 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
