Question about RCA TH1611 MP3 Player
I keep buying batteries and I just wanted to know can I charge it on the computer and if so how?!!!!
  • 60 Answers
This device does not have that capability. Your cheapest solution would be to buy a battery charger and some rechargeable batteries. WalMart has one for under $10 that includes charger with two AA's and two AAA's included. This way you could be charging one while using the other of the AAA's.
Posted on Feb 03, 2009
I keep getting the message "connecting to computer" on Samgsung SH100
Disconnect the camera, remove the battery and after a few moments reinsert the battery. Then switch on again.
When you charge the battery in the camera, the camera could think it is connected to a PC, because the USB cable is inserted. It could be you are using a USB cable, that not came with the camera. If the error keeps coming back buy an external (Universal) charger, to charge your battery. Modern universal charges can charge almost every camera battery on the market. In the long run, it is better for the camera and for the battery, when you charge in an external charger.
Keep the contacts clean with a dry cloth.
May 10, 2014 | Samsung Sh100 black 14.2mp 5x Zoom Digital...
Acer Aspire One battery only charges to about 23%
Sadly, the only other thing you can do is buy a new battery in this instance; or continue with what you're doing.
One of the things you could do, is do not charge the computer until it dies. Batteries have a life span, and this as you may or may not know is reduced by charging, or even worse damaged more by just keeping it plugged in, charging it when it's half way charged and such on so fourth. You can increase life span by just letting it die, and then recharging it. It sounds like your battery has got to a weak point from all that charge, unplug, fall, charge. I apologize for your battery.
Feb 23, 2013 | Acer Aspire One Netbook
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
My dell latitude c400 does not take a charge do i have to buy a new battery ?
Yes, most likely you may need to replace the battery. Try to get a different cell capacity this time (I do not know if you currently have a 6 cell or 9 cell battery). Once it's not keeping a charge it most likely has a problem.
Hope this helps...
Apr 18, 2010 | Dell Latitude C400 Notebook
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
Computer not charging with universal adapter
hi i had the problem before , you have to buy dell charger in order to charge your battery, universal charger doesnot work with this, the only way not to lose your power is to keep the charger connected, in this way the battery will not be charged but u will not lose the power. again you need dell charger the universal only gives power but doesnot charge.
Best Regards
Mar 23, 2009 | Televison & Video
It doesn't It is like a flash light battery.It is only on when the computer is turned off to keep the BIOS settings. Try replacing the battery,if date is not kept.
Mar 01, 2009 | Computers & Internet
Apple ipod not getting charged
First, please check your connection (I'm sure you have already done this). Make sure that the cable is plugged in and working on both ends.
If that is fine, I would recommend taking it back and getting a new one. If you just recently purchased it, you should be able to return without a problem. It sounds like you might have a defective product and you don't want to get stuck with it after the return period.
Good news is that when you get the new one, if you use iTunes, it will automatically sync up and you wont have to manually load songs.
Hope this was helpful but if you still have questions, let me know.
Have a great day
Nov 13, 2008 | Apple iPod nano
Failure to keep charged
did you try to buy a new battery
Jun 29, 2008 | Compaq Presario Notebook
RCA TH1611  MP3 Player Logo
43 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
