Question about Zanussi WJS1397W Front Load Washer / Dryer
The ZANUSSI WJS1397W unable to open door handle is floppy
I have takern top of and layed machine on its side. I can get may hand to the back of the lock but cannot feel or see anything to release the door any Idea's
  • garry_pettit Feb 04, 2009
    Thanks so much for your advice i was unable to fix it. I call out a local service man. He sniped the handle of then unclicked the door with a screw driver removed the door undid the back of door replaced the handle then refitted the. he was no more than 10 min parts and Labour £30. I'm happy and i know the wife will be evern happyer. again many thanks for you prompted reply and help.
    Scholar:
  • 86 Answers
Hi, You can just about get your hand inside the machine and down the front of the machine if you push the drum back at the same time. You will be able release the door lock if the pnuematic lock is not stuck open! If this is the case then you will need to pull off the hose on the bottom of the door to relase the lock be fore any attempt is made to relaese the door catch from the lock. Once the hose is off then you can open the door. But you will need to change the air chamber that is the big plastic chamber that sits in the front of the machine that the pump connects to as it will be full of scale from the water and they cannot be cleaned out. You will find that the machine will be more efficent and will spin dry the clothes better as your machine is and has been filling up to much with water.
Good luck and let me know if this helps..
Posted on Feb 03, 2009
Will ntot start and door will not open
The door lock has failed & needs to be replaced.
Feb 06, 2012 | Zanussi WJS1397W Front Load Washer / Dryer
Unable to open door
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Zanussi FL884 Washing Machine door lock broken.
More likel that the door latch or handle is broken.
Only way to open door now is to remove the top cover and force the door lock open from inside, you may possibly break the lock by doing this, but there is really no other alternative.
Mar 29, 2010 | Washing Machines
Zanussi washing wjs1397w machine not working
john, as with all electronic items you should unplug for 1min then plug back in and attempt normal selections.
Aug 19, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
We have a Zanussi washer/dryer WJS1397W but only a cold feed where we want to put it. We were wondering if this machine could cope with a cold feed only?
It shold not be a problem if the machine gives you a choice choose the cold wash.The manual should tell you which wash cycles are cold wash only.Hope this helps Kind Regards Stefan.
Jul 08, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Door will not open. lock handle floppy.
take top off and see if you can feel for the door peg sticking thro the interlock and operate by hand.
also, you can chew away the door handle and operate the door peg with a small screwdriver.
the door handle kit will need replacing anyway
Sep 11, 2008 | Zanussi WJS1397W Front Load Washer / Dryer
Washing machine
there is something caught in the hose's going on the filter,or something in the pump,drain water again lay machine down on its side,so you.................................can see what you are doing remove and check all hose's,for sock or the like that,happy Chrismas Ire!!!
Dec 24, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
How to replace door lock
FACE DOOR DOWN ON A TABLE GLASS UP, REMOVE ANY SCREWS. IE. TWO].USE FLAT SCREW DRIVERS TO PRISE APART THE TWO PLASTIC SECTIONS, LIKE TAKING TIRE OFF BICYCLE, IT SHOULD BE EASEY TO FIT CATCH THEN. GET BACK IF YOU HAVE PROBLEM. CLOSE IRE GOOD LUCK, TOP OF THE MORNING TO YOU
Nov 08, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Settings dial has broken on my Zanussi WJS - 1397W
You can go to this site and find/order the parts to fix it. It looks like the top of the machine just pops off (held down by clips) which then exposes the control panel and allows access to fix. Hope this helps.
http://www.espares.co.uk/diagram/washing-machines/zanussi/wjs1397w/p/1085/332/0/407647?ed=3912
Oct 27, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Zanussi WJS1397W Front Load Washer / Dryer Logo
268 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
