Question about Acer Aspire 5100 Notebook
Cannot double click on my mouse pad to make a selection.
I went to the control panel and lowered the speed of the mouse clicker but i think that seems to only affect the right and left buttons on the pad and not the pad itself.
thanks
    Problem Solver:
  • 14 Answers
This tends to happen in vista due to some driver compatibility issues and has nothing to do with your click speed. Download and install the latest driver and I am positive that it would resolve the issue.
click here to download the latest drivers
Posted on Feb 03, 2009
How to make a optical mouse work better?
Your mouse is an important part of your computer system, and when that mouse has problems it is important to get them resolved as quickly as possible.
There are a number of things that can cause a mouse pointer to behave erratically, and it is important to work through each of those possible causes one by one.
Change the batteries if you are using a wireless mouse.
The batteries in a wireless mouse will generally last a long time, especially if you use rechargeable batteries.
But once the battery power begins to decline, the batteries will lose power very rapidly.
If you are using a wireless mouse and the cursor begins to stutter and jump, chances are that changing the batteries will resolve the issue.
Move the wireless transmitter to another USB port.
Problems with the wireless transmitter can cause the mouse pointer to stutter and jump. Moving the transmitter to another port will often resolve this issue.
Right-click on the "My Computer" icon on your computer's desktop, and choose "Properties" from the menu.
Click on the "Hardware" tab, and click the "Device Manager" button.
Navigate to the mouse entry in the list of hardware devices, right-click and choose "Update Driver" from the menu.
Allow your operating system to search for and install the most recent driver for your model mouse.
Clean the mouse surface thoroughly if you are not using a mouse pad.
If you are using a mouse pad, shake any dust or dirt off of it to make sure the surface is perfectly smooth.
Any imperfections in the surface could cause the mouse pointer to behave erratically.
To clean the mouse surface, hold a clean cloth over the opening of a bottle of isopropyl alcohol and soak the cloth.
Then, go over the entire surface with the alcohol-soaked cloth and allow the surface to dry before attempting to use the mouse again.
Click on the "Start" button, and choose "Control Panel" from the menu.
Double-click the "Mouse" icon, and click the "Mouse Pointer" tab.
Adjust the speed of the mouse.
If the mouse speed is set too fast, it can cause the mouse pointer to stutter or hiccup.
It may take a few tries to get the speed just right, so just move the slider and test each new setting
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Hope this helps
Nov 04, 2012 | Computers & Internet
Touch pad double click is not working. How to cure?
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Jul 09, 2012 | Dell Computers & Internet
My hp pavillion dv6 track pad will not double click. please help
If you can right click, you can select all the double-click options, like Open. Or, click and hit Enter on the keyboard.
However, the double-click may have been inadvertently set to fast. Go into Control Panel and change the click speed in Mouse settings.
Jul 05, 2011 | Computers & Internet
Double click not working
go to printer hardware in control panel;
select mouse;
lower the speed of double click.
Jun 19, 2011 | Acer Aspire One PC Notebook
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
I have to click twice or three times to get any action to happen on my ThoinkPad T43p
Hi, it seems that the Mouse click speed is slow, try increasing the Speed. It might help you. To increase the Mouse speed follow the steps.
Press and hold Windows Logo+ R key, this will launch the Run command prompt.
Then type "Control" in the Run Command prompt, to open Control Panel.
Now select the Mouse Option in the Control Panel.
Check the double click speed, move the slider to fast and check. Please get back if the issue still persist.
Dec 08, 2010 | IBM ThinkPad T43p Notebook
Hi, my acer 3820TG touch pad seems to be too sensitive is there away to calibrate it?
Hi jace_bingzho,
You can adjust the sensitivity of the mouse according to your requirement. Just follow the instructions below:
1) Click on Start.
2) Go to Control Panel
3) Double Click on 'Mouse'.
4) The Mouse Properties dialogue box pops up.
5) In the pointer options tab, under Motion, there will be a slider under 'Select a pointer speed'.
6) Move the slider with your mouse towards 'Slow'. Now you will notice that when you move your mouse, the sensitivity has decreased.
7) Apply the settings and Click OK.
Hope this information was helpful.
Thank you for using fixya,
Arun Zac
Nov 26, 2010 | Acer Computers & Internet
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Mouse will randomly double click or have to click several times to work
Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
You could also try going into Control Panel --> Mouse
Try Slowing down the double click speed
If that doesn't work try speeding it up
Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
Oct 18, 2008 | Logitech Cordless Mouse
UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
you can solved this problem by following these: 1. Find the icon of your pointing device in the taskbar (mine is synaptics pointing device) 2. point to the icon and right-click on it. 3. check if "Tap To Click" option is checked. 4. if not, then click on "tap to click" option so that it will be checked. 5. try now to double click using the touch pad...and you will be okey now.
Sep 04, 2008 | Dell Latitude C610 Notebook
Acer Aspire 5100 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
