Question about Viper Security and Remote Start System (basic install included)
I cant disarm my alarm
Ok this is the thing Ok this is the thing i have a 5900 viper alarm on my car and my transmitter is damaged and the damn alarm keep on arming on its self, i had my car about 3 yrs and this is the second time the alarm arm its self. the first time (about a yrs old ago) i got it to disarm but this time im have not luck.
And the manual say to turn the ignition to the ON position. press the valet button the preset number of times (1-5 times) within 15 sec. after 5 sec, the system will disarm.
I keep on doing that but nothing happening
  • Landon V.W May 11, 2010
    The me Make this Clear... DONT SWEAR ONLINE
  • 43 Answers
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Posted on Apr 01, 2009
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
Viper alarm(car) when replace batt(car)alarm goes off like crazy
should be able to close everything on car and just hit the unlock button should disarm if not you may have to hold the valet switch to reet
May 10, 2012 | Nissan Vehicle Parts & Accessories
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
How do i disarm my viper without transmitter
Turn on your ignition and press the valet button switch under the dash and the alarm will turn off.
Jul 18, 2010 | Viper Security and Remote Start System...
Need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Jul 20, 2009 | Viper Vehicle Parts & Accessories
Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Jul 07, 2008 | Viper RCVGC022 Remote Control
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
1,088 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
