Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
Posted on Feb 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clothes still wet aftre drying cycle over
The clothes come out hot, but very wet. Fluff filter is clean. the dryer is spinning OK it seems...cnat figure out why it isnt drying
Steve Allison
Level 3:
  • Bosch Master 5,569 Answers
  • Posted on Feb 03, 2009
Steve Allison
Bosch Master
Level 3:
Answers
5569
Questions
Helped
2000803
Points
16452
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 • Dryers
1helpful
2answers
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
1helpful
Dryer gets too hot on regular laundry setting but seems to work ok on delicate laundry setting.All vents and filters are clean.When using regular setting when drying is done the clothes are too hot to...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
I have an indesit widxl146 washer drier and the machine takes an age to dry clothes, 9 hours as oppose to 2 hours when new
9 Hours!!! I hope it isn't because the clothes are too wet because if it is I wouldn't like your electricity bill!!
There are a number of things you need to check.
I assume that you are not overloading the machine, and that you are using the correct spin cycle
Don't start the drying cycle directly after the wash, take out the clothes and see how dry they are after the wash, you need to ascertain if it is spinning the load sufficiently fast to dry them. How dry are they directly after the spin? If they are not wetter than they should be then the dryer is not getting hot enough during the drying cycle, this could be due to a faulty thermostat or element.
Make sure all the filters are clean including the pre chamber down below so that it can pump out the water (I guess it must be clear if it is washing ok? but check anyway.
The principal parts involved, assuming that
Also check that you haven't got a delay set for the dryer (unlikely I know but I thought I would mention it anyway)
I hope that helps.
Thor laundry system won't dry clothes I have a thor no venting washer/dryer combo machine, that has been working fine for years. Suddenly it is not drying clothes and instead, clothes are soaking wet...
I am having the same problem on a WD9900A. The wash cycle works great. Spins fast and clothes are completely rung out. Dryer cycle heats up well. Fluffs and heats cloths. At some point during dry cycle water is injected on clothes and they end up sopping wet; much wetter than after wash. Filter is clear. Outlet pipe clear and functions well. Possible problem with dryer timer? Or washer timing kicking back on?
6helpful
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Excess fluff on clothes
you should clean filter after every load. If dryer is getting unusually hot (cabinet), then you may have a plugged vent line. Check where vent is on the outside and see if plenty of air is coming out of it. If not it is plugged up
Dec 03, 2008 • Dryers
2answers
Low heat, not drying
There´s a sensor inside that controls the temperature in order to prevent overheating.
Mostly they work with resistance. Oxydation can influence the resistance value, as like as some fluff.
Second option: you have perhaps not only one heating coil, perhaps one is not working.
Needs 2 drying cycles
I am assuming you are cleaning the lint filter. Check the vent pipe out the back. If it vents into the wall, the piping leading to outside may be plugged. Your washer is spinning the clothes good, right? If the clothes are excessively wet they will take longer to dry also. If its practical, remove the vent hose and let it dry blowing into the room. It may suck but just once for a test.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
