Question about Frigidaire GLTF2940ES Front Load Washer
Wont spin at end of any cycle
Frig. Washer model FTF2140ES0. The washer goes thru every cycle just fine but wont spin in any cycle. The failure code come up as E43 which in the tech sheet says to replace main control board. The new control board behaves the exact same way with the same failure code.
Any help would be appreciated.
  • jeffersonrom Feb 05, 2009
    the machine wont spin and its has water inside the spinder
  • 367 Answers
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
Posted on Feb 03, 2009
  • Justin Duby
    Justin Duby Feb 04, 2009
    Just talked my buddy (another repairman) and he is working on another one of these machines with the same problem. This machine i a lemon. If you can get rid of it... I would.
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Frigidaire FTF2140ES0 Front Load Washer lock indicator light goes off, but will not spin.
Sounds like the electronic locking mechanism is malfunctioning. It is supposed to enguage before the high spin cycle. It is about a $20 part.
Sep 20, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Jan 04, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Washer wont work at the spin cycle phase
you nead to replace tjhe door switch.the part#for the door switch is 8318084.
Nov 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
345 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
