Question about Sony STR-DE675 Receiver
Surrond sound not working
My rear speakers are not working with the receiver. The receiver shows only 1 S on the display for the back speakers. How can I get ot to show RS and LS speakers
    Problem Solver:
  • 17 Answers
It all depends what digital mode you use ,yes in Pro Logic mode on the display it shows only 1 S but if you try the balance for the SL-SR you will hear the difference .
Posted on Dec 17, 2009
All speakers work on sound level test but i have no music coming from rear, center and sub when playing 5.1 dvd. also i am unable to use any of the surrond sound modes. richard
What cable did you hook up your dvd? The 5.1 sound works only with optical cable or HDMI. Check in the input settings wich one is selected. With the analog cable ( Stereo RCA) is not working. Good luck!
Jan 29, 2011 | NAD T762 Receiver
Power/standby light is lit. When I try to power on, the display shows "digital" then "av surrond", then the unit powers off; the power/standby light flashes. I tried unplugging to reset, but no luck.
you receiver is reporting that the impedance of the speakers is incorrect the manual says that it needs impedance of 6 to 16 ohms and when simultaneously using a and b it needs 12 to 16 ohms. but you receiver is also saying that the problem is with the av surround digital channel so the impedance of the speakers is either too low or too high check the impedance of the speakers and if they are correct try them on another circuit and see if the problem follows the speakers.
Also, it may be that the positive wire is contacting the back of the receiver and grounding out. If so reduce the length of the bare wire and reconnect.
you may have to reset your receiver to clear this state.
turn off receiver or start from the off condition,
hold down surround mode left and right and turn on the receiver hold all 3 buttons till the display starts flashing at intervals of aproximately 1 second then release the buttons, if this fails to work try the procedure again.
Cheers!
Feb 14, 2010 | Denon AVR-1601 Receiver
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
Volume wont work
In the menu for initial setup look for a setting for center channel and turn it off. If it is on you will have no sound because it turns the TV speaker into the center speaker for a surrond sound receiver input.
Jun 27, 2008 | JVC AV-48P775 48" HDTV
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Feb 09, 2007 | Amphion Mediaworks T-365 System
Surrond Sound Rear spaeakers
yeh i get the same problem.. i have 5 speakers hooked up to my str- de475 and cannot get sound from my sl/sr speakers its a nightmare aint it? why is there no soloutions on the net for?
Jan 16, 2007 | Sony STR-DE475 Receiver
Sony STR-DE675 Receiver Logo
157 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
