Question about Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
WHEN I TURN ON THE COPIER I GET THE ERROR CODE C0500, CALL FOR SERVICE.
How to reset malfunction code C0500 of a imagistic
Posted on Sep 20, 2011
  • 26 Answers
Low fuser temperature during warm-up
Posted on Feb 08, 2009
When ever i switch on the minolta Di 181 i am getting an error code CO500 and the copier sitches off automatically
Posted on Aug 27, 2012
Reset c0500
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Aug 08, 2016 | Office Equipment & Supplies
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
C0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
Error code C0110 on imagistics copy machine which model number is C650
The only reference to that particular code is:
C011
Backup memory problem
Problem with thebackup memorydata.Defective backup ram.
Jan 21, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Codigo de falla CO500 en imagistic modelo 2520
la fotocopiadora presenta una averia y me sale cod c0500... quiero saber como puedo solucionarlo
Jan 30, 2011 | Office Equipment & Supplies
How to reset malfunction code C0500 of a imagistic im2020 copier
On the side of the control panel, there is a little hole, use a paper clip unbent to press the switch inside hole. The touch screen will restart. watch the left hand side 2/3 up, a little dot will appear, when it does, press 3. The login in is all zeroes. press trouble reset and then turn off and on using the switch at the left side, lower back edge of machine.
Nov 06, 2009 | Office Equipment & Supplies
I have an imagistics copier zc55 and I'm getting an error code C-12C6 when I start it up. Where can I get information on what this is.
Turn the copier off and on. If the error comes back, there is a problem with the image processing board. Call Oce for service 1 800 243 5556
Oct 08, 2009 | OCE Office Equipment & Supplies
Imagistics Error Code C-0B77
May want to check the stapling unit and hole punch. To reset open close front door. After openclosing finisher door
Jul 03, 2009 | Office Equipment & Supplies
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Konica Minolta DiALTA Di200 Copier Logo
2,914 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
