Question about IBM ThinkPad 600E 2645 Notebook
The computer will not boot up. It has an icon of a lock only. JD
When I turn on the computer, the screen is blank except for a small lock pictured in the upper left hand corner. I removed the inner battery for a few minutes thinking that this would break the lock, but it did not.
It appears that the computer is going to boot up, but then the lock appears and nothing else will work.
If you can advise me what to do, I would appreciate it greatly.
J. D.
  • bocas Feb 06, 2009
    I have exactly the same problem. I've been to a repair service but they say that there is nothing they can do and I will have to take it to a service centre and have a new 'mother board' fitted. As we live in Turkey and the only service centre is in Istanbul, a 16 hour ride away, I'd be really grateful for another solution
  • galata132 Mar 21, 2009
    I have the same problem, but I am in Istanbul. can you give me he phone number of the Service Centre ?
    Problem Solver:
  • 10 Answers
Pull out all wire then put them back in this will work
Posted on Feb 03, 2009
Why can't I boot the computer in safe mode! Please can anyone help only I want to update it to windows 7 or 8. The message that keeps coming up reads : The exception unknown software exception (0xc0d007e)...
It looks like the a system file is corrupt. Pressing F8 just before it boots should let you choose safe mode. If it doesn't, reinstall windows as a repair.
May 11, 2014 | Computers & Internet
Blank screen
Did the laptop boot up all the way except the screen is blank? Do you hear fans running and the hard drive spinning, lights on? If you think it booted except the screen is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 23, 2012 | Computers & Internet
My computer is on and has a blank page and it will not let me get to startup
What do you mean blank page? And what is startup? Is startup the desktop with your icons? Tell exactly what happens and what you see when you power on the computer.
Maybe you are saying your system booted up all the way except your screen is blank. If so try the steps below.
May 20, 2012 | Dell Latitude C510 Notebook
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
Picture is too large for screen
Adjust the display settings on the computer by right clicking anywhere on the desk top except on any of the icons - a blank area. Select properties then select display settings - adjust to the desired or correct resolution.
Dec 17, 2010 | Dell E173FP 17" LCD Monitor
I have an emac G$ 700Mhz 128MB/40GB/Combo with two related problems: 1. On power up, I get a blank grey screen that, after a while, changes to a similar screen, except that at its center is a small...
I've never used a hair pin-- a straightened paperclip has always worked for me.
One alternate solution (if you have another computer available) would be to boot the eMac into target disk mode by holding T during startup. It should show a firewire icon on the screen, and should act like an external hard drive when you connect it to another computer via a firewire cable. You can use this method to install the OS onto the eMac from another Mac. You can try Googling "Target Disk Mode" if you need more information.
Nov 13, 2010 | Apple eMac G4 Desktop
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
I turn on my mac and only this small folder icon appears in the middle of the screen
The face is probably frowning.  The computer cannot find the operating system.  Use a utility disk to boot up the computer and then use First Aid or Disk Utility to check the disk.  You may have to re-install the operating system.  This can be done without losing your files if done correctly.  Seek help from an Apple repair facility if you are in doubt about how to do it.
May 20, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
My icons won't show up
Try right-clicking on the desktop screen > View and make sure that "Show Desktop Icons" is ticked.
Jun 24, 2008 | Toshiba Satellite A105-S361 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
273 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
