Question about Tappan TGF657 Gas Kitchen Range
I HAVE AN OLD TAPPAN GAS RANGE WITH PILOTLESS IGNITION
The front left burner when turned on does not light..no igniter sound.
All the other three burners light ....and you hear the igniter clicks....What is the problem with just this one front left burner. I do smell gas when the fron left is turned on.
I'm not sure what the model number is but here are some numbers:
191T122F408 6/9/1986 I guess this is the date
30-3348-23/01028-88056763
316T035P01
jsrock516
  • 5911 Answers
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
Posted on Aug 04, 2007
  • 145 Answers
SOURCE: burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Posted on Apr 23, 2008
huuum
  • 750 Answers
SOURCE: Tappan gas range burner ignition
Hello paultoledoWelcome to fixya.
I'm Huuum and happy to assist you,
You said, You got a 5-year old Tappan gas range. Two of the burners don't ignite, the other two and the oven are fine.
What do you need to do to fix the problem?
Sounds like a yes from where I'm sitting, your right on target, buying a new spark module will fix it.
That sounds like the spark modules.
I think you are correct!
Let me know if you need me!
Please remember to leave a solved rating!
Huum
Posted on Sep 24, 2008
SOURCE: Tappan oven not gas flow or ignition
You were right, it was the igniter. $55 dollars later, all is well. I did not know that the gas will not release into the oven if the igniter wasn't hot enough to open the valve. That's why I was afraid it was a faulty valve. I was under the impression I could just light the gas with a match, but that was not the case.
Posted on Nov 17, 2008
duby1990
  • 370 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
I just cleaned my Tappan NF40700643 Automatic Pilotless Ignition gas oven and now the light bulb (bulb is good) the and oven does not get hot .... it does nothing. Help ... I have dinner ready to put in...
if not even the light bulb is working it sounds like the plug is out or the fuse blew,pull the stove out,plug in a hair dryer or something to see if there's any power at the outlet or just go check the fuse or breaker box
Aug 16, 2011 | Tappan TGF363 Gas Kitchen Range
Tappan front right side burner gives out very little flame...
sounds like a ignitor problem or a dirty burner.clean all the holes of the burner and if you could see the oraphas clean that as well.
Mar 06, 2010 | Tappan TGF320 Gas Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Nov 19, 2008 | Tappan TGF320 Gas Kitchen Range
Huum
Sep 24, 2008 | Tappan TGF657 Gas Kitchen Range
I have a kitchen aid model kgcg260sob3 front burners wont light without a match
it could be the electrodes or the burner itself. get a technician to check it.
Dec 16, 2007 | KitchenAid KGST307 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
380 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
