Question about Bloomfield 8572 Coffee Maker
Coffee comes out cold . it seems to me the heating eliment is not working. is this easy to replace and where can i get the part. iam in cleveland oh. and is there a repair center in my area.
  • 72 Answers
Hi this is tech crazy
The problem in your coffee maker is due to the above said reason:
To keep the heating element from overheating, there are also components such as sensors and fuses. In coffee makers, sensors detect if the coil is getting too hot and cut off the current. Then, when it cools down, they turn the current back on. By cycling on and off like this, they keep the coil at an even temperature. Fuses simply cut the power if they sense too high a temperature. They're there for safety reasons, in the event that the main sensor fails.
From my experience i personally feel that replacing of theses things would cost almost to a new coffee maker machine.
So,its left to you sir/madam to decide upon the new coffee maker machine.
Kindly rate me on the above said soltion
Posted on Feb 03, 2009
Inside fan is working but heat exchanger ices up and fan freezes and unit won't cool.
This means the heating eliments are not coming on. Usually in this case I change out the heating timer, eliments, and thermostat. All as a set.
Aug 29, 2015 | Haier HRT02WNC 1.7 cu ft Compact Counter...
Coffee machine kenwood model es547 ligts come on but water will not heat up
Try unplugging it for several iuets in an attempt to re-set it..
If not - could be that the heating eliment failed.
Jul 11, 2009 | Coffee Makers & Espresso Machines
Heating element on an lavazza expresso machine
you can call this number they will help you with your problem
1-866-526-6204
Apr 15, 2009 | Lavazza Espresso Point Capsule Machine
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
Dont want that cold cuz iam already ther
The heater element sensor are open or fuse/ motor ok /flow of air ok heater is the problem.replace fuse or heat sensor if open.
Jan 08, 2008 | Heating & Cooling
Thermistor value
Are you speaking of the thermal fuses?? There should be a value like 102c or 110c or something like that. if both sides of the heating coil thermal fuses are open they got that way for a reason as they dont just open up. They are there so your house dosent burn down. Make sure that the heating coil didnt go bad and change resistive value as drawing too much current would overheat the coil and cause these puppys to pop open, PLEASE BE CAREFULL Oh and if the markings burnt off the device, go to black& Decker's web site as I order parts for my tools all the time, put in the model # get the parts list as well as part #s and prices to order them. Good Luck
Apr 10, 2006 | Black & Decker SpaceMaker ODC325 Coffee...
Bloomfield 8572 Coffee Maker Logo
143 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
frankecoffee
Level 1 Expert
rhodesworks
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
