Question about Canon imageRUNNER C3200 Copier
Error code E000025-0000
Tech recently adjusted the toner sensors, now unable to print without getting this error code every 1-2 copy
  • 679 Answers
1) Drum unitIs the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Good Luck
Posted on Feb 03, 2009
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
We have Konica Minolta Bizhub 250 What does error C2557 mean
Error code c2557 means "Auto Toner Density Control sensor abnormality" (ATDC)
Sep 20, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Sharp MX-M450N getting F2-00 error and the AR455NT toner not working.. i know it means sensor open it is a new machine and already getting error... cant find nothing in manual on how to repair this issue
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
Jul 29, 2010 | Sharp AR-BC260 Color Copier
Error code e03-40
---Copy Density Sensor output adjustment-----
1. Sensor connector is disconnected.
2. Sensor is defective.
3. SPC PCB connector is disconnected.
4. SPC PCB is defective
there is a sensor in the drum unit that measures/sensors toner density on the drum. the sensor is usually dirty and needs a clean. there could be a number of causes so a technician needs to be called.
May 01, 2010 | Panasonic Workio DP-3520 Copier
Error COF30
toner sensor cannot b cleaned have to replace it
Jun 22, 2009 | Minolta EP1083 CS/PRO Copier
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
Canon imageRUNNER C3200 Copier Logo
787 people viewed this question
old marine
old marine
