Question about Nintendo 64 Console
Lights on no gameplay :*(
Well basically everything is connected but when you turn it on nothing happens i got the right channel and everything but i was playing mario64 around 4hrs ago then iot hasn't came on sionce ..
ps-- being in a bag around a year and half .. is it smashed ??
  • arabella417 May 01, 2009
    everything plugged in, TV tuned console on, got some writing on the screen which i cant read, but no game play
  • 48 Answers
It takes a lot to smash this bad boi.
Make sure to clean out the system connectors (the spot the game sticks into) by opening the flaps and blowing into it, and clean the game as well.
Posted on Feb 03, 2009
I have a 95 Dodge stratus..2.4 L. The past week it was having trouble starting. After turning key off then on..3..sometimes 4.. it would start right up. Next morning had to do same thing. Yesterday I took...
Yes, it has to do with the ignition switch. but just as possible could be a battery connection from the battery to the switch. So, sometimes turning key to ON causes no dash lights or warning lights to come on?
That sounds like a bad switch, or more likely, a bad battery connection or a bad connection between the battery and the switch. First thing to do is check the charge of the battery, it must register at least 12 volts. 12.6 volts is the ideal for a good and fully charged battery. Clean and tighten all battery connections.
Sometimes when you have a poor connection, from looseness to corrosion, and you turn key and see all warning lights and gauges come on, and then turn key to start and everything goes black...that can happen because the power surge causes the bad connection to come apart. So check for loose or corroded connections.
Mar 02, 2018 | Dodge Cars & Trucks
There is a constant high pitch noise on the left input channel.
Sounds like you may have a defective unit. I would return it for exchange.
Oct 29, 2015 | Behringer (UCA202) Sound Card
What channel can I use for my wii as i get nothing
Unlike some older game consoles, the Wii does not have an RF output, meaning you don't tune the television to a specific channel to use it. The Wii uses composite video output using three RCA-type plugs. You will need a television that supports these inputs or an RF adapter.
Jun 08, 2014 | Nintendo Wii Console
1999 suzuki srad, when i press the starter button nothing happens, rode yesterday with no problems, lights and everything else works
okay....assuming battery is charged....didn't run down overnight...start with the basics..
is the Kill switch (Engine stop) on the right bar in the RUN position?
is the bike showing its in NEUTRAL?
Normally you can crank in gear...but only if the sidestand is up, and the clutch switch is satisifed by having the lever pulled in.
If none of thius works....test battery voltage, battery connections.
Apr 14, 2011 | Suzuki GSX-R 750 G Motorcycles
My 2000 saturn sl wont start. it has power everything lights up. But nothing when I turn key. Happen last week and started right up a day later. happened again last night and nothing again this...
There should be a small black wire going from the battery to the starter motor. It sounds as though it has come loose.
Check it and re connect it.
I hope this works.
Good look
Sep 20, 2010 | Saturn S-Series Cars & Trucks
Audio problems with Alesis RA-150
on bridge mode the speaker impedance should be 8ohms, less than this clipping will happen. try bridging two 4 ohms in series.
if this happens without speaker connected, u have a power amp section that is trying to draw more power than it can handle.
as for the second check connections first, otherwise i suspect u have a defective power amp for the right channel.
Mar 12, 2010 | Alesis RA-150 Amplifier
My psp randomly resets during gameplay.
Format the PSP's drive, but back everything on it up first.
Aug 16, 2009 | Sony PlayStation Portable (PSP) Console
I cant plug in my ps2 to my tv!!
Soi didnt exactly fix this but basically i figured out that the ps2 is simply too old for that new tv. when i plugged in a newer system it worked just fine so i guess ill just have to deal.
Dec 13, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Nintendo 64 Console Logo
167 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
