Question about Protron PLTV-32 Television
I am having difficult time HD on my 32" set. I went and bought a HDMI 6ft cable, and connected it,and removed all connections running in the left side except one, being the audio, change the channel to AV2. Doing all this, I feel I have gain was a good digital picture but not true HD. I was informed at WAL-MART to touch base with you for help on this matter. Thank you; Bob Weschler
    Sergeant:
    Champion:
  • 289 Answers
Hi..For gaining a good HD Picture u have to
install a HD software.After installing that software
only u will be able to get the HD clarity videos.This
Clarity will definitely make some difference when u
compare with that normal video.U can ask about this
to your television expert itself.He will solve ur problem
of High Definition Clarity.
thank u..
Posted on Feb 03, 2009
  • Hariharanath V Feb 09, 2009
    hi..the best is to call your tv mechanic for
    your problem.
    try this out..
    thanks..
  • 679 Answers
The only way to get better image quality is to either get more power (juice) to the box/TV, or to upgrade to HD service, if you have cable, it may be a good idea to split your cable connection, connect one cable to your cable set-top box, and connect the cable box to the TV with composite cables (yellow/white/red cables), then take the other cable from the splitter, and connect it directly to your television, then do a channel scan, you should be able to get your standard basic channels, and you will be able to get unblocked digital channels, and some HD channels, and for the blocked digital channels, just switch over to your cable box, as for your static filled channels you should be able to get them on basic cable pretty clear
Thanks for using FixYa.
  • rockfixya
    rockfixya Feb 03, 2009
    or you can try a Booster to boost up signals>>
    read from>>
    http://www.laaudiofile.com/accell_hdmi_1...
  • Protron Master
  • 19,396 Answers
Check the receiver HDMI settings, try also switching |TV in put channels with the remote.
  • Protron Master
  • 13,433 Answers
Hi
This television is HDReady 720P which is not full HD (1080p)
I'm not sure if there is anything you can do to improve this.
Its a HD TV but not the best HD available.
If you need anything else let me know.
We bought a hitachi 50hxt 16u tv and are unable
tried to replace the HDMI cable then set the right source.check also your box which not working.
Nov 02, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have a Sony bravia 32" (KLV-32T400A) and have just bought an xbox.. On trying to connect it using the HDMI input an error comes up saying that it's not a supported signal. I also tried plugging my laptop...
All hd-ready tv's only support max 1080i and not 1080p. The default setting on the Xbox is 1080p, that's why you get that message. There is a way to fix this, just follow the steps below:
Connect TV and X box via HDMI cable with units switched off.
Switch both units on.
  1. Press the right arrow 7 times (Left top jog knob on game controller)
  2. Press "A" button 4 times (Green button)
  3. Press "up" arrow once to set to 1080i
  4. Press "up" arrow once again to set to 720p.
  5. Press "A" to store setting
Sep 12, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have an optoma HD20 and it connects using a 1.5m HDMI but as soon as i try a 10m HDMI connection (even with a booster it does not connect) any suggestions welcomed?
Hi kgomer782 I have similar issue. My optoma hd20 signal connection with a 3/6ft hdmi cable is perfect. However, no signal is detected when connected to a 35ft hdmi 1.4 cable. The 35ft cable is indeed working becuase I tested it succesfully when connected to a 1080p HDTV. Did you received any solution to your problem? I wonder if it has anything to do with the HD20 design of the "debossed" hdmi ports that prevents the cable plug from getting completely "seated" in the port? My 35ft cable has a flat square male ending however, the 3/6ft cables have slim male ending that seems to accomodate perfectly in the Optoma's hdmi port design...kaufmanekpr
Aug 07, 2010 | Optoma HD20 DLP Projector
Samsung lcd 720 ln32b360 doesn't fill screen in 16:9 mode. Went through tv setup, connected it to hd box (verizon Fios) plays all HD channels but does not fill screen as it should. TV is connected to set...
If by regular cables you are talking about the standard red/yellow/white composite cables, then, yes, it will affect HD as composite cannot send an HD signal. Only HDMI and component (red/blue/green video only) cables.
Change to HDMI and let us know if it works for you.
Jan 07, 2010 | Samsung LN32B360 32 in. LCD HDTV
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
Oct 03, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Picture shifted to the lift
Press menu on remote and tab over to settings
Scroll down to tilt correction
Sep 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Protron PLTV-32 Television Logo
71 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
