Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Will not power on.
The camera was dropped and no will not power on. What should I do? Can I fill out the Canon Warranty or should I take it somewhere to get repaired?
  • Anonymous Apr 14, 2009
    i have the same problem but i dont thik it was dropped&the battery is fully chargerd. =/
The most common fault on a piece of kit that has been dropped is that the solder lead will snap on the heaviest component. Usually the battery or a capacitor, resoldering will fix the problem. However disassembly is the difficult bit
Posted on Feb 03, 2009
Dropped my canon sd 1400 IS camera now it wont turn on and i am in chile but have a warranty on the camera, what can i do?
Dropping the camera voids your warranty. It would be a miracle if they fixed it for free.
Jul 10, 2011 | Cameras
My canon cameras screen won't turn on but the camera works, what might be wrong??
Have you dropped it recently? If so, the ribbon connecting the screen might have come loose. If it does have a warranty, you will want to contact Canon and see if the issue is covered.
Otherwise, remove the battery, hold the power button to the on position for 10 seconds, then release. Place the battery back into the camera and turn on. This might clear any issues with power the screen might be experiencing.
Mar 05, 2011 | Canon PowerShot SD700 IS Digital ELPH /...
When Turning on the Canon Power Shot A530 the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Camera will not power on
If you have a warranty that covers dropping, send it in. If not try contacting Canon, go to this link and plug in your information. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=12913
Sep 05, 2009 | Canon PowerShot SD600 Digital Camera
My wife dropped our Canon A470 camera on a concrete surface. The camera will turn on but it displays a lense error message asking to restart camera.
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 29, 2009 | Canon PowerShot A470 Digital Camera
Canon A560 dropped.when the cam is on lens wont retract anymore
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon Rebel XTI isnt getting powered on after few drops of water fell on the lens and the screen.
Such symptom indicate a malfunction on the DC/DC voltage converter circuitry or the main board, caused for moisture as result of the water drops.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform some basic diagnostics of the failure. You will need tools to do it, which includes the usage of a soldering iron.
The repair cost may be so huge that is cheaper to buy another camera, since after open it, it may be necessary to replace multiple expensive parts.
Best regards,
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Clicking noise
You don't want to be having clicking and popping or grinding sounds. Call Canon and see what your options are: if under warranty, possibility of being covered unless dropped or sat on or something. if out of warranty you can still have it repaired or upgrade/replace camera for a deep discount that will include a 6 month warranty.
Hope this helps!
Mar 29, 2008 | Canon PowerShot S3 IS Digital Camera
Dropped camera now it will not power up or anything battery is charged
You probably blew a fuse. Maybe the lens jammed and the motor could not overcome the jam so it shut itself down to protect itself. I dropped my first camera, under AMEX warranty and it came back with 3 fuses repaired, no physical damage-just wouldnt turn on.
Feb 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
