Question about Canon PowerShot SD1100 IS Digital Camera
Not taking clear photos
When the lens comes out or goes back in it makes a noise. the camera will not focus clearly. the screen is very blury.
I am having a similair problem I contacted Canon and they said it could be a sensor problem and they will look at it for free and if it is the sensor they will fix it for free they are even sending me shipping label. My camera is out of warranty by a few years.
I called 1-800-828-4040 and spoke with repairs. Good Luck
Posted on Feb 05, 2009
Focus circle clear but surrounding area appears hazy
This is often the result of little available light on the focus screen. The more ambient light (and more open the aperture is) the brighter and sharper the image is in the viewfinder. Less light effects the image in the view finder and makes it harder to see and focus.
If your lens only opens to f3.5 or 4.0 and you\'re trying to shoot indoors with available light - your lens may not let enough light into the camera to see the scene as well as you can with the naked eye. An f1.4 aperture lets eight (8!) times as much light as an f4.0 does and is why they\'re so expensive.
Try the same setup in a brightly lit (sunny day) scene to see if it goes away.
Apr 06, 2014 | Nikon FG 35mm SLR Camera
Blury screen
HI there your screen is ok but sorry to say that the lens does not focus because the lens guide pin is damaged or dislocated. So replaced the guide pin or repaired it. After that your camera will work properly. Thanks & waiting for your feedback.
Apr 02, 2010 | Olympus FE-270 Digital Camera
The pictures i take are blury how do i fix it
If you don't know how to use the manual focus switch it to auto focus, Check the MACRO feature, try to capture photos about 2 inch or 4 inch nearby the object, if the shots are clear and shooting in distant objects are blurred meaning you have set your camera to MACRO setting, Turn off the Macro feature
Oct 31, 2009 | Fuji FinePix S3000 Digital Camera
Camera will not take clear photos
As you have noted the lens is the root cause of this noise problem. I really believe there is grit in the lens gear thats preventing it from zooming or re-tracing. As for the blurring this can happen due to shutter lag.. a notorious problem in some of the powershot models. Either ways your camera needs service by an authorized professional. I would not advise you to try and clean the lens gear yourself as it can very easily get messed up and it would significantly rise the cost of the repair.
Good luck
Sai.
Feb 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Fuzzy photos
Turn the small dial to the right of your view finder either "+" or "-" until picture is clear inth eview finder
Jan 09, 2008 | Canon Digital Rebel / EOS-300D Digital...
Focus problems
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Sep 19, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
109 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
