Question about Whirlpool Washing Machines
Reinstalling whirlpool front load washer bellow
I have the old bellow out and and i'm having a difficult time putting the new one in. any suggestions?
  • nysmassage Feb 03, 2009
    i solved the problem myself. i took off the lower balancing weight to get at the bellows better.
  • 32 Answers
The easiest way to replace the bellows seal is remove the complete front panel.
This will really help: Duet front load washer repair manual
Posted on Feb 03, 2009
Purchased my Whirlpool front loader 4/2004, we are on our 7th bellow, new inner...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Feb 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to reinstall rubber ring between door frame and washer tub on a whirlpool duet washer
The rubber ring is called the "bellow". The following link explains the steps necessary to install one:
Make sure you inspect the bellow to ensure it has no leaks or tears, first. Re-installing a damaged bellow will only result in a leaky washer.
If its only the front bellow clamp that needs to be re-installed, skip down to step 12. If the rear clamp has come loose where it attaches to the front of the wash tub, then you will have to follow all the steps that require you to remove the front panel. It may sound intimidating, but its an easy repair if you follow the steps provided.
If you have any questions, please let me know. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Replace Bellow seal duet washer GHW9100LW1
Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front Loading Washing machine door gasget leaking
These arent terribly difficult with mechanical capabilities. The clamp which snugs the bellow to the tub (toward the inside) can be tricky. The front is snugged by a spring loaded cable. Also, take care to align the fill tube at approx. 10 oclock looking at it from the front. And make sure the fill tube is entirely through the hole in the new bellow. It can get frustrating but usually takes less than 30 min.
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Thank you for your advice on replacing washer bellows
Chuck Askew, We would like to inquire further about your post with you. Please respond back to this email address with your name, user id (Chuck Askew), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 19, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Suggestion on replacing Bellow/front seal
Dont do it, it takes time to learn this and how tight to put on. It could be a disaster(seen it first hand)
Nov 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
not hta tbad takes alittle patience and a third hand wont hurt either. theres aspring holding the front of the belllow in place peel it back slightly youll see it, pop the spring, and then theres a clamp holdin the bellow to the inner tub, youl find the relaesa (eitehr a phillips or possibly a 7/32 socket i beilieve) afeter releasin ghte clamp its a matter of working the new bellow around the same li[ the old came off of, it may take some time but aftger its all on just resecure the clamp.(oh yea before starting to refit-- the new one slide it over the water fill first. the tricky part and thord hand will be need trying to stretch the spring back pver the front lip
Apr 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal De
