Question about M-Audio FireWire 410 External Sound System
XP freezes on startup from Firewire external HD
I have a Dell XPS 400 and a WD external HD. When I plug it in via firewire (1394, IEEE) the computer freezes on startup. Using the USB cable, the computer has no problem. I've been meticulous about narrowing this problem down. I first thought it might be the HD driver. Updated...no change. Updated WD software...no change. Tried the turning HD off prior to startup...computer booted normally. Tried with USB and HD turned on at startup...no problem.
Tried updating my VIA OHCI Compliant IEEE 1394 Host Controller Driver. Couldn't find a newer driver than version 5.1.2535.0
Any thoughts b/c I'd really like to have the speed of firewire for my backup drive?
This sounds silly but its true...the m-audio 410 doesn't work with windows, especially not with vista. It works on mac but barely. I've been screwing with one for 3-4 yrs now and have gone through a few that died and never had one with 0 problems, always too many to count. It works on macs but barely. it still has tons of problems on the latest and greatest. Bottom line - m-audio is crying because they're totally incompetent at making cards... or they don't give a rats a** about anyone not spending over $500.
Posted on Apr 17, 2009
  • donk atron Apr 19, 2014
    Having wrote this solution quite some time ago, I thought to add some clarity for anyone who stumbles upon this. For just about any firewire device, ESPECIALLY sound cards and ther sound devices, you need to be certain of your firewire card's chipset in your computer. Texas Instruments is the only reliable chipset for windows users from what I have heard. I had already given up by then in favor of Mac OS X for 99% of audio and media needs for similar problems.
    tl;dr version - If you make music, get a mac, seriously. Too expensive? Get an old, slow used one, it's still better.
I need a hookup layout for audiofire4 connecting to a Roland XP 80 and to a computer
if your computer has a Firewire (IEEE 1394) port, you can use a Firewire cable to connect one of the AudioFire4's Firewire ports to the computer's Firewire port, then hook up your XP80 to the MIDI ports on the AudioFire4. Connect MIDI Out to MIDI In.
Sep 07, 2013 | Echo AudioFire4 Portable FireWire Audio...
How to connect firewires of the HD?
You just need to plug one end of the firewire (IEEE 1394) cable into the external hard drive and the other end in the slot on the computer marked IEEE 1394. Sometimes you have a IEEE 1394 slot on the front panel, and sometimes it's just on the back of the PC.
If you find you don't have a firewire (IEEE 1394) port on your PC then you will need to get adapter that will change the firewire to a usb. If you have trouble finding one of those then install a card like this in your desktop:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124002&cm_re=usb_to_IEEE_1394-_-15-124-002-_-Product
Jun 21, 2012 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
How to connect firewires?
Good Luck!
How can i download the contents of my mini tape onto the pc ?
you don't convert the files, you just downlod them via a firewire comnnection.
If you have a mini dv (cassette) camcorder....
Your dv camcorder needs a firewire connection (ieee 1394) in order to download video, your PC probably did not come with a firewire port, so you will have to buy one and install it, since most computers (except possibly brand new) don't come with a firewire port, your camcorder did not come with a firewire cord so you have to purchase a cord too. Your camcorder did come with a USB cord and that is used for downloading stills from your camcorder. Make sure your camera is in playback mode.
Open your editing program and choose the capture mode.
The fine print in your manual makes reference to firewire (ieee 1394) connection....
thanks.
Apr 11, 2011 | Cameras
What dose the icons mean on front panel what is the little square hole for next to the mike connection
hello, it is most likely a firewire connection.
FireWire, originally created by Apple and later standardized as IEEE-1394, actually preceded USB and had similar goals. The difference is that IEEE-1394 was originally intended for devices working with lots more data -- things like camcorders, DVD players and digital audio equipment. IEEE-1394 and USB share a number of characteristics and differ in some important ways. Here's a summary:
  • Like USB, IEEE-1394 is a serial bus that uses twisted-pair wiring to move data around.
  • However, while USB is limited to 12 megabits per second, IEEE-1394 currently handles up to 400 megabits per second.
  • USB can handle 127 devices per bus, while IEEE-1394 handles 63.
  • Both USB and IEEE-1394 support the concept of a isochronous device -- a device that needs a certain amount of bandwidth for streaming data. This mode is perfect for streaming audio and video data.
  • Both USB and IEEE-1394 allow you to plug and unplug devices at any time.
hope this helps,
regards
Amar Sondhi
Dec 05, 2009 | Medion M3 Director 5100 PC Desktop
How to connect IEEE 1394 (4 pin) to computer
IEEE 1394 is commonly referred to as Firewire. Your Dell doesn't support it. You will have to purchase a firewire adapter card and install it and its drivers into your computer.
Apr 22, 2009 | Dell Dimension 2400 PC Desktop
Dell Optiplex GX620 will not recognize firewire controller card
1394 drivers should be native to XP, you may be able to correct this by running an SFC scan
Take out the IEEE1394 card
Insert your Windows CD (if you do not have it order a backup from dell)
Exit out of 'install screen'
click Start
click Run
type 'sfc /scannow'
press enter
you should see a progress bar, when finished restart the computer
this compared critical windows files on harddrive vs CD, and replaces missing and corrupt files
Feb 03, 2009 | Dell 2-Port IEEE 1394 FireWire CardBus PC...
Dell Inspiron 1525 - Firewire not working
It may be the communication setup.
You might need to set within the Camera PTP protocol.
The WD drive specs out a 6 pin connector, not a 4 pin.
Nov 17, 2008 | Computers & Internet
SONY HANDYCAM DCR-TRV280
To download video you need Firewire port, also known as an IEEE 1394 port.
Windows XP or Vista can save your video files.
PCMCIA 2-Port IEEE 1394 FireWire Laptop Cardbus PC Card
Jun 26, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
USB Connection Problems
You say have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. You then say sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. Fire wire is a different system with a different connector style- so it should not be in a USB port or a USB connector should not be in a Firewire device. Get you device and connections sorted The desktop display simply puts up a device it will not differentiate which USB or Firewire
May 23, 2007 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Open Questions:
M-Audio FireWire 410 External Sound System Logo
386 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
