Question about Sony Handycam CCD-TRV608 Camcorder
Head Cleaning Do you recomend a wet or dry type of cleaning cassette?
  • 10,594 Answers
Please use good quality video head cleaning tape. Dry tape is better if you are about to clean camcorder video head.
Posted on Feb 03, 2009
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
Video head need cleaning is it wet or dry
The best way to clean a video head is to remove the top outer cover, then you can spray the head with Servisol Video 40. You can also spray the audio/control head at the same time. You can get Servisol from electrical shops and also online (image below).
May 09, 2010 | Quasar VHQ400 VHS VCR
My heads on the xm1 seem to be dirty, ive used a sony cleaning tape, it only makes a difference for an hr or two taping, any sugestions
Firstly, I must explain how the MiniDV system works:
Although this may sound illogical, MiniDV camcorder heads do actually use a type of lubrication cassette system and there are 2 types:
- DRY lubrication (Canon, Panasonic, JVC etc)
- WET lubrication (Sony)
Now, if you haven't noticed already from the above 2 types, you are in fact using the WRONG type of cassette on your camcorder.
Although Sony cassettes are often readily available (and often perceived to be the best quality), by using Sony cassettes on a Canon camcorder (or Pana, JVC for that matter), you are in fact causing premature wear on the heads. So, the condition you are describing as 'dirty' heads, is in fact caused by the use of the wrong (wet type) cassettes on your DRY type camcorder.
Using "WET" type cassettes on a DRY system camcorder, can often leave residue on your heads, or worse....cause wear. The same principle applies to Sony camcorders - use only Sony 'WET' type cassettes, not Dry cassettes.
This also applies when using HEAD CLEANER cassettes - as indicated, you have used a Sony Head Cleaner cassette (this is a WET type cassette), when in fact, you should be using a DRY HEAD CLEANER cassette (Pana, Canon etc).
CAUTION: when using a head cleaner cassette, only playback the cassette for no more than 6 sec's at a time (anymore will damage the heads).
Summary:
For your Canon camcorder, use only DRY MiniDV cassettes (Pana offer cassettes from Studio, Professional to Master Quality), including DRY Head Cleaner cassette. This should improve the playback quality from your camcorder.
Mar 25, 2010 | Canon XM1 Mini DV Digital Camcorder
Canon gl1 camcorder dead pixel and artifact when
I know this camera well !
This is likely to be your heads, but you need to be made aware of the following:
1) MiniDV cassette
The quality of your cassettes should first be considered:
Panasonic, Canon and several other brands use what is called "Dry Lubricant" cassettes. For this reason, you should AVOID at all costs, any cassette made from a manufacturer whose cameras use Wet Lubricant type cassettes. Unfortunately, this means you should AVOID SONY cassettes (as Sony cameras use the WET lubricant system).
Dry type cassettes also cause less wear on your heads.
I would highly recommend you use only Panasonic PQ (Professional), SQ (Studio) or MQ (Master) quality cassettes.
(PS: I use these Dry type cassettes on my Canon Pro Camera)
2) Camera HEADS
As stated in above (re the cassettes), if you have inadvertantly used a WET type cassette in your camera (i.e. Sony or similar), have been using old cassettes or debris/dust has entered the compartment, then there is a high probability that some microscopic contaminants may have fouled your heads.
If so, your heads will require cleaning.
The good news is, Panasonic have a MiniDV Head Cleaning cassette (DVMCLA) which can be purchased for around $8 - $15. (try Amazon.com).
If you choose to use this cleaning cassette, it is EXTREMELY IMPORTANT that you only run the cassette for a max. of 5 seconds ONLY, for each clean (and no more than 10secs, as using this cassette longer than stated, can cause wear). Then, try playback of your old cassettes to look for improvement. Cleaning is only necessary, if you experience drop outs on dry type cassettes, or pixelating of picture playback.
If this head cleaning process does not resolve your problem, then you will require professional assessment.
Good Luck !
Nov 24, 2009 | Canon GL1 Mini DV Digital Camcorder
The DV tape is totally macroblocking during playback. Is this an indicator of dirty heads?
I've just posted this solution to another user:
1) MiniDV cassette
2) Camera HEADS
Good Luck !
"if this has helped you in any way, please rate this solution"
Sep 24, 2009 | Canon GL1 Mini DV Digital Camcorder
It records but not watchable, cannot put in a tape from another machine and watch it.
Try cleaning the heads with a wet-type cleaning cassette. You're describing a classic symptom of dirty heads. This is commonly caused by using a tape that's worn and leaves some of its oxide surface on the head.
May 04, 2009 | Sharp 13VT-R100 13 in. TV/VCR Combo
Sound but no picture
Most likely the VCR needs a head cleaning. This is common when playing older or rented tapes as the oxide recording surface can flake off and clog the video heads. You can try a head cleaning cassette. Make sure to get a wet-type cassette which you moisten with the included cleaning fluid.
Unfortunately this is not always successful for severely clogged heads. It may be necessary to remove the cover and clean the heads with a chamois cleaning swab moistened with head cleaner. Hold the swab flat against the round drum that holds the heads and move the drum back and forth while holding the swab steady. Repeat this for each of the heads. The heads are fragile and can be damaged by incorrect cleaning, so you might want to see what a shop in your area charges. (The shop I worked in used to charge $20, but that was several years ago.)
There's also the chance there's been head failure or some other problem has developed, but dirty heads are very common.
Jan 08, 2009 | Panasonic Televison & Video
My dvd has sound and picture, no picture but sound on vhs
try cleaning your VHS head, use wet type VHS cleaner cassette
May 04, 2008 | Televison & Video
Help
Try cleaning the entire Tape path, as I suspect a dirty Control Head. Since it is not wise that you open the machine and do it yourself, buy a good quality 'Wet Type' Head Cleaning cassette, and use as per instructions.
Jun 23, 2007 | Sony SLV-SE820 VHS VCR
Sony Handycam CCD-TRV608 Camcorder Logo
258 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Sheryl Bahr
Sheryl Bahr
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
