Question about Lexmark X4650 InkJet Printer
No wireless printer port for lexmark x4650
Hello...my wireless x4650 does connect just fine to my router. But when I ran the install cd, it said that the connection failed. After some research, it seems that the correct port is not in the printer properties, but I cannot seem to add it. The only port that works is the USB port, but I wanted it for the wireless ability. It will print wireless if I connect it to the "print server" wireless connection, but that is not the same as my actual network.
thanks
  • 1 more comment
  • jredfern Feb 03, 2009
    thanks, i am at not home, and cannot verify, but that seems pretty good. A question though....do I add it from the Exceptions tab? And then once I click on the add port button, it asks for "name" and "port number". I assume I add the ip address there?
    thanks! on xp professional by the way.
  • jredfern Feb 04, 2009
    Excellent, worked perfectly.
    Thanks!
  • Anonymous Mar 14, 2009
    printer seem to be connected to the router but i can see it anywhere on my pc!!!!!!!!!!!what to do????????
  • 432 Answers
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Posted on Feb 03, 2009
  • Raymond Scott
    Raymond Scott Feb 03, 2009
    Add the name of the printer when you set it up and add (I think its) port 427.
    For me, I named mine ( HPOffice01 ). I setup an ip port to print on ip 192.168.1.3 that I setup for the printer. In firewall Exceptions, check ' File and printer sharing'. Then go to printers, right click your printer, select 'Sharing' to share the printer on the network. Now, beside sharing is ports. Add an ip port you want set for the printer. ( some printer have an ip like 168.243.129.43). Give it a try. After you get home from work, email me.
  • ravi
    ravi Feb 11, 2014
    192.168.1.1
I want to set up a wireless printer connection, but I lost the installation CD.
Please visit the Lexmark website to download and install the Lexmark X4650 printer driver on your computer. Select your operating system > download > execute the file. Just follow the instructions on your computer screen.
Sep 19, 2011 | Lexmark X4650 InkJet Printer
I have a new router connected to my laptop and i lost the instalation CD. How can i connect my lexmark X4650 to my new router?
Why would you ever, ever use the CD a thing came with to install drivers? The ones online at the maker's sites (or service site) are, bar few, much better choices.
Outside of that, if they're both 802.11g, they'll both have sync buttons so you can just hit the one on the router, then the printer, push printer buttons in an affirming way, then go to your laptop and print the queue (or backlog, or whatever.)
Aug 06, 2011 | Lexmark X4650 InkJet Printer
How do i connect my computor with my printer using no cables
If you have the installation cd that came with your printer, insert it in your computer and run the installation. It will come to a point where it will ask you your preferred connection type, choose Wireless. Just follow the instructions and enter the requirements. This article may be able to give you additional assistance: First-Time Installation of a Lexmark Series Inkjet Printer in Infrastructure Mode (Wireless Routers and Access Points). You may contact Lexmark technical support for additional help. Thanks.
Jan 17, 2011 | Lexmark X4650 InkJet Printer
Just installed software cd for lexmark X4650 on laptop with windows 7 64 bit. Productivity Center app won't work. setup wireless print - works fine. Get a popup that says to download m.NET Framework 2.0...
You will need to use the Lexmark X4650 driver for Windows 7 64-bit from the Lexmark website. First, uninstall the existing driver from your pc. Go to Start menu -> Programs -> Lexmark 4600 Series -> Tools -> Uninstall. Reboot your pc when prompted.
To reinstall, click on this link Lexmark X4650 Driver for Windows 7 64-bit. Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Jan 13, 2011 | Lexmark X4650 InkJet Printer
DSL line problems required us to reset the wireless router in the process the Lemarck x4650 no longer connects to laptop. Fix?
get t the wireless card of the printer ..and reconnect it in the actual conditions of the router ..just open the card ..and scan for network ..when you find it ..connect ...and insert the network password if it has the security activated..Practically connect the printer again like you connect a wireless laptop ..
If the connection is made to one of the ports of the router ..by cable ..than open the lan card in the printer and insert the values corespondent to the position in the port .. or put it to automatically (obtain an IP address automatically ) if the router supports it ..and it is not necesarry to insert the addresses a manually ....if it is ..get to the other option ..use the following Ip address ..and insert the values like in the computer that connects in the near by port ..only at the IP address insert the last digit with one unit more than the port near it ..like thi s..
if the printer is in the 4th port ..and the computer near it in 3rd has the Ip address 192.168.1 4..the printer will became ..192.168.1.5 (they are always with one digit more..cause the router is 1..the rest since the port one are from 2...3..and so on ..
Aug 26, 2010 | Lexmark X4650 InkJet Printer
Wireless printer gets ip address different from my routers ip add
Check on the wireless network the printer is connecting to. Make sure it is your router.
Feb 03, 2009 | Lexmark X4650 InkJet Printer
Can't get my wireless printer to receive a signal from the router
I would take that printer back. I do not know which store you bought it from, but from my troubleshooting experience rule out that it is in fact not the printer. Another one taken through the same paces will tell you that. Then you know that it is something outside that printer or some question or parameter not answered right during the installation process. Good luck and God bless.
Jan 08, 2009 | Lexmark X4650 InkJet Printer
Failure to install X4650
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
677 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
