Question about Broan-NuTone Allure III QS330SS Kitchen Hood
ALLURE WS2 SERies range hood fan doesn't work but lights do
The fan and lights on the hood were both working while we used a new George Foreman grill on a different circuit to burn off the factory coating, which produced some smoke. Suddenly the fan went off but the lights stayed on the range hood and we have been unable to get it to work (the fan) ever since. We checked the fuse and it is working properly. It is a fairly new range hood that is used infrequently.
Has anyone else had this problem and/or do you know how to fix it.
Thank you
  • Larry Rogers Feb 06, 2009
    Not sure what you mean by test the wires.
    If the wires aren't connected then it will not work. Please explain further.
  • 19,396 Answers
If you had smoke then something has shorted or blown inside.
There is need to take apart the unit and access to the motor, motor control board, and wiring harness to test them using a multimeter.
If you have voltage to motor, then the motor must be replaced.
Posted on Feb 07, 2009
    Master:
  • 416 Answers
Did you check the fan motor itself.
If there is burn smell fan motor is dead.
But it might be just stuck. Renove the filter and try to rotate fan manually to see it there is free movement. It not motor might be dusted/clogged, try to vaccum or blow it with hair fan, if no help motor is dead, needs replacement. If thre is rotation look for incoming wires for burn/damage. Also check house fuse/braker box, maybe one switch is off.
Good Luck
Posted on Feb 06, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, it would appear that the smoke from burning of the factory coating of the George Foreman grill triggered the fault. Some ideas you may want to consider:
  • reset the logic/electronics controller. Unplug/disconnect from the mains or switch off the breaker;
  • the electronic controller operates on separate circuitry and would still operate even if the fuse is blown;
  • the electronic controller uses a small isolation transformer to bring down the 120VAC to a lower voltage. The LED indicator lights should lit up when their corresponding buttons are pushed;
  • if not, the the controller board is faulty or it is not receiving power;
  • if yes, then problem is either with the fan or the switching system (possibly relays) for the speeds of the fan;
  • if on pressing any of the fan speed button, fan would not turn but there would be a humming heard or vibration felt on the the hood's body, then it would possibly be a faulty motor capacitor.
Pls post back results or updates of any developments. Good luck and thank you for using FixYa.
  • 367 Answers
One thing you can do is take down the hood and wire in a regular 110 plug and just plug it into the wall. Then see if the fan works. If not then it is either the fan switch or the fan motor. You can go to just a hardware store and buy a 2 way switch to see if this the problem. If this is not the problem then the fan motor has gone bad. Buy a cheap switch to test it first. This may all your problem is.
    Genius:
  • 2,120 Answers
There should be 1 or 2 button shaped THERMOSWITCHES / THERMOSTATS attached to the side of the hood.
Turn off the power and remove the wires.
Tape the wire ends to prevent a short.
Test
Step 2
Connect the 2 wires together with elec tape
Test
  • 6,784 Answers
Ok, the Foreman grill didn't do this at all, this sometimes happen when you cook or fry on a frequent basis. the frying smoke that is produced during frying anything can pass threw the screen and some of the sticky participates can become lodged inside of the windings inside the actual motor that spins the fan around. in time, this sticky residue can prevent the motors rotation speed from reaching its limit, therefore, causing it to get unbelievably hot. this usually causes motor malfunction that will lead to failure. i suggest a total fan motor replacement.
Posted on Feb 05, 2009
  • 716 Answers
Most Vent Fans Are Just Plugged Into A Plug Once You Remove The Bottom Screen If This Is The Case Unplug The Fan And Try Plugging Something Else Into The Plug. If You Find Out The Plug Works Then The Problem Is The Fan And It Will Either Need To Be Replaced Or Greased. Try Turning The Fan Motor By Hand While Its In The Off Position If It Is Very Difficult To Turn It May Need To Be Oiled. If There Is No Plug Pull The Wires Off The Motor And Check That There Is Power There. Please Post Your Results Here
Sincerely,
Michael Scott
  • 1 more comment
  • Michael Fisher
    Michael Fisher Feb 06, 2009
    Heres An Exploded View The Fan Motor Is Number 19.
    Also You Can Click Here For A Larger Image.
    A Lot Of The Parts Are Available To Buy Here
    But Not The Motor Which Can Be Ordered From Here
    And If Needed The Units Specifications They Are Here
    Depending On How Many Inch's Across Your Unit Is The Dimensions May Very In The Description.
  • Michael Fisher
    To Test And See If They Are Live When The Unit Is Turned On By Using A Voltmeter. These Wires Are Live When The Power Is On So Do Not Touch Them When The Unit Has Power.
  • Michael Fisher
    More Info: If No Power Is Found At The Wires To The Motor Check Power Before The Motor Capacitor. The Motor Capacitor Can Be Viewed In The Exploded View I Provided In My First Post.
    If Its Bad You Can Buy It Here
    Its $5.00 Cheaper From This Site Then It Was From The Other Site I Provided For Parts.
    Also The Installation Manual Will Be Very Helpful For Disassembling The Unit. Click Here For The Manual
    Genius:
  • 2,920 Answers
See if you can check the wiring on it to make sure none of the wires burned through,,
    President:
  • 1,596 Answers
I Have Installed an Exhaust fan and THE FAN was FAULTY from the start so Dont RULE OUT the Idea that the FAN itself IS FAULTY this is What I Suspect here.
  • 1,800 Answers
Does everything works fine Sir.
only the FAN is corrupted.
  • Jalal Sordo
    Jalal Sordo Feb 05, 2009
    please??
  • Jalal Sordo
    cceck the connections please.
  • 124 Answers
Just take it back to store u got it to get it replaced or call the manufacturer and they can look up your warrenty
    Brigadier General:
  • 8,619 Answers
Hi!
Please check for the wiring inside the hood, wires maybe burnt or short.
  • 1 more comment
  • Rylee Smith
    Rylee Smith Feb 05, 2009
    If the fuse has opened (blown), the green fan-level indicators
    will operate properly when the fan buttons/switches are pressed
    - but the fan and lights will not turn on.
    The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
  • Rylee Smith
    Please check this service manual for your kitchen hood--
    Thanks
    Rylee
  • Rylee Smith
    If this doesn't help then definetly the control board has failed.
    It is Part # R111638.
    The part is available at: www.inventex.com
    Thanks
    Rylee
    Top Expert:
  • Broan-NuTone Master
  • 63,242 Answers
HAVE U LOOKED IN THE HOUSE CIRCUIT BREAKER BOX JUST TO VERIFY U DID NOT TRIP A CIRCUIT BREAKER? I HAVE A SIMILIAR GRILLE AND IT DRAWS ALLOT OF AMPS, SO JUST VERIFY THE CIRCUIT BREAKER IS NOT TRIPPED.
  • yadayada
    yadayada Feb 06, 2009
    get a volt meter that reads AC voltage and test the wiring to the blower motor, u should show about 115 volts, if not then check the circuit breAKER
  • yadayada
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
2. Fan switch
3. Fan motor
Am cleaning up my range top and noticed that when I pulled out the drip drawer....there is a light blue/green wire by the grill that is only attached at on one end. Not sure if I pulled out the...
You can call Viking and they will know for sure.I would think,as it is of comercial quality,that there may be a wire or more on the back.Most likely to connect to an ANSUL system,a type of fire suppression.It could also be for a vent hood or some attachment like a rotisserie.You can call them at 1-888-VIKING1 (1-888-845-4641).
May 12, 2011 | Viking 48" 6 Burner, Grill Professional...
Fan working,grill gets hot but the oven doesn't
NEEDS NEW FAN HEATING ELEMENT.
ORIGINAL WENT ON MY A2 AND I REPLACED WITH A STRONGER
3 ELEMENT INSTEAD OF THE 2 ELEMENT ORIGINAL.
IT'S BEEN FINE SINCE.
May 11, 2009 | Smeg A2.5 Dual Fuel (Electric and Gas)...
New World Classic 100 cooker
The closk and ignition is no longer working, how do I solve this?
Aug 27, 2008 | New World Ellingwood 100 (Gas) Kitchen...
Parts for George Foreman Grill GR20BW
Hello Rod01,
After some research, I found no parts resource for your GR20BW bun cover (I'm not saying that such a resource doesn't exsist though). So other than replacing the grill or repairing (if it's broken) your existing cover, that buying a used one at an online auction site (or wherever you can find one) for parts (if the cover is intact on the parts grill) would be a place to start looking. I tried and didn't find anything for your GR20BW, but did find a few GR10BW grills.
I hope this helps, and Good luck.
Mar 07, 2008 | Kitchen Ranges
My george foreman grill doesnt switch on when i turn on the plug, can you please help me?
Make sure you have power to the wall socket. Try the Grill in a socket you know that works. If it still doesn't light up and work chances are the cord or power lead could have a break in it and may need either replacing or shortening if you can find the break. If the Grill works in another wall socket then the wall socket you were using it in will need to be checked and maybe need replacing. Hope this helps.
Regards
Bryan
Feb 23, 2008 | Kitchen Ranges
Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Sep 25, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
460 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Richard Roth
Richard Roth
David Burbee
David Burbee
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
