Question about HP Pavilion a705w PC Desktop
No output to monitor, light turns yellow
When i turn on my computer the inhibited light turns yellow with no video output
  • 23 Answers
Check to make sure the Video cable is still firmly seated on both computer and monitor. Next the case may need to be opened up to assure the graphics card has not been unseated from the main board.
Also make sure no pins have been bent or disturbed on each Item.
"computer graphics innerface. and Monitor."
Posted on Feb 03, 2009
My sa200 will not turn back on
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 22, 2014 | Samsung SyncMaster SA200 Series 19in LED...
Why has my monitor turned orange. model dylm19r6 computer monitor
If you mean the light on your monitor is orange instead of green, it means the monitor is not receiving data from the computer.
Jul 14, 2014 | Soyo Computers & Internet
Monitor will not turn on and power light blinks blue
Good luck.
Jul 10, 2014 | Sylvania Scm2401 Curtis Lcd Monitor 24"...
Blinking on/off light.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 06, 2014 | ViewSonic VA1913w Monitor
Viewsonic VX2640W was running with the screensaver on,then suddenly went solid white. Turned off for thirty minutes then back on with same result. Unplugged from computer and turned on. Still turn
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Feb 03, 2014 | ViewSonic VX2640w LCD Monitor
Screen scrambles
Jan 05, 2014 | ViewSonic VX900 19" LCD Monitor
Monitor will not turn on after extended periods
Aug 16, 2013 | ViewSonic Computers & Internet
My monitor turns on with a green light and then immediately changes to a yellow light
Sounds like you have no video output from the motherboard. Unplug your desktop computer from the wall so no power is going thru it. Take out all the memory sticks from the slots. Then go ahead and reseat one of them in any slot. Then with the Monitor hooked up turn on the computer. If you still don't get video then repeat the steps and try the memory in each other slot.
If you have more then one memory stick try each one in each slot. If you still have no video after trying all the slots with each different memory stick then that means the motherboard is bad.
If you have a external video card that was installed then take that out and use the internal one that your motherboard came with and swap out the memory using that.
Basically your turning off the computer swapping memory out in each slot and turning the computer back on to see if you get video to come back on.
Feb 05, 2012 | IBM Aptiva E 500 (2158500) PC Desktop
Turn monitor on and the light stays yellow will not turn green and screen stays black
When it lights up the yellow light instead of the green one, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | Computers & Internet
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
HP Pavilion a705w PC Desktop Logo
308 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
