Question about Coffee Makers & Espresso Machines
Krups Homecafe lid is stuck shut, cannot open
I cannot ope the lid on my Krups Homecafe pod coffee maker. How do I fix this problem and why is it happening
  • 2 more comments
  • tlowell Feb 22, 2009
    Same thing, lid is stuck, won't open.
  • letzshop Apr 08, 2009
    I have a KRUPS Programmable Thermal coffee maker and the lid will sometimes stick due to the vacuum caused by the internal heat. this time I simply cannot get it open and don't know how to break the vacuum hold on this lid.
    PLEASE, this seems to be a common problem and I would love to know some suggestions to help get this thing OFF.
    Is there any HELP out there?
  • arthur_il May 08, 2009
    I have the same problem with Senseo 7823
    http://www.fixya.com/support/t236560-stu...
    Look for Petra's solution
Http://www.fixya.com/support/t236560-stuck_senseo_maker
Look for Petra10 solution
It worked for me!
Posted on May 08, 2009
How do your repair the Cover-Filter Holder for a Krups XP2280? Part # MS-622631.
Don't both sides make coffee? One brews into a large glass beaker the other into a cup.
Nov 16, 2016 | Krups Coffee Makers & Espresso Machines
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Why won't the lid open?
Part number is MS-622958 and it is still a current active part. Any Krups service agent will be able to order one for you. Let Google be your friend. I can't order it for you because I'm not in the USA and that is the only country your model is available for.
Jun 05, 2015 | Krups Dolce Gusto KP 2100 Espresso Machine
Tassimo lid stuck
Common problem with them. They are having issues with the lids locking and not unlocking.
They suggest you call 1-877-834-7271 customer service.
They've been having people return them.
Jul 23, 2014 | Bosch TASSIMO Coffee Makers & Espresso...
Hine ran out of water while making coffee. Now it wont work.
Sounds like an overload fuse has blown (possibly) there are resettable fuses in some, not in others. Have you checked you element?
Apr 07, 2012 | Krups Dolce Gusto KP 1006 Espresso Machine...
A pod burst in the bag. I tried to clean the pods off the best I could, but apparently there were a few grains on them. When I pushed the button on the right it came on for a few seconds. The grains...
fill the unit up with a bottle of peroxide and let stand for an hour. It will soften the gronds to a muddy consistancy so it will flow out. Add water and brew in an hour. It will clean out the unit as well like new
Sep 13, 2011 | Philips Senseo HD-7810 Coffee Maker
Can the lid on the Krups Aroma coffeee pot be taken apart to clean?
Yes!!! by the word lid do you mean the top or swing out filter holder? If you use small flat screwdriver you can expand plastic at hinge enough to pull apart!
Mar 17, 2009 | Krups Aroma Control 229 Coffee Maker
Broken Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker?
My Krups was not working after I accidentally forgot to place the black plastic lid on the coffee carafe BEFORE starting to brew a new batch of coffee. The coffee will not drip into the carafe without the lid
in place. Because the lid is hidden when placed in the coffee maker, it's easy to forget! The coffee all backed up in the filter area and overflowed. The display got wet. Not good.....
If your buttons and or display is not working ( mine got wet with coffee) simply flip the coffee maker over. Unscrew the bottom. expose the display circuit board carefully, DRY it with a HAIR DRYER and put the unit back together! Presto! Mine is working again.
If you need a new circuit board, you can get one for $35 from Appliances.com I found. They also have the Duo filter and extra parts cheaper than the Krups website.
Feb 22, 2009 | Krups FMF5-14 Stainless Steel 10-Cup...
Coffee Makers & Espresso Machines Logo
788 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
