Question about Sony RM-PP404 Remote Control
Sony remote rm-pp404---master volume buttons
Dear Sir,
Lately my master volume buttons + - are not working at all, last month it started on & off ,now it stopped--other buttons are already working.
Now is remote gone wrong or receiver volume knob is gone wrong ???
I would appreciate your help--thanks
  • 1 more comment
  • kppatel004 Feb 03, 2009
    Your Help will be appreciated to solve the problem---Thanks
  • kppatel004 Feb 05, 2009
    as to clean remote ,how much cost since i do not know to clean inner circuit.please gve me repair cost---thanks
  • kppatel004 Feb 09, 2009
    thanks
    Brigadier General:
  • 3,614 Answers
Service a remote control:
  1. Open the battery compartment (see Household Battery Fix-It Guide) and remove all batteries.
  2. Remove any housing screws located in the battery compartment or on the bottom of the case.
  3. Remove the case and inspect the circuit board for damage. If the board is dirty, spray it with electrical contact cleaner and use cotton swabs to dry it.
  4. Remove the keypad and gently wipe the surface with mild soapy water and let it dry.
  5. Use canned air to blow out dust and debris from the housing.
  6. Once all components are dry, reassemble the unit and install fresh batteries. You may need to reprogram codes in the unit following instructions in the owner's manual.
Posted on Feb 05, 2009
  • micromaster
    micromaster Feb 05, 2009
    if you still have no idea how to do this. let me know your location, and i find the nearest repair center near your place.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the volume chip that is inside the remote
could have got damaged.so ur volune control
is not opersble.Remotes r available in the market.
once u say ur model no of the remote correctly
they will provide u with the proper remote.This is wat happens
with the electronic goods.Once it is damaged it cannot be
used.
thanks..
Posted on Feb 03, 2009
  • Hariharanath V Feb 09, 2009
    hi.. u give it to your local electronic expert
    he will do it for you.
    try this out..
    thanks..
    hi..It will not be too costly.They will be charging
    you some minimum charge.
    check it out..
    thanks..
    Sergeant:
  • 250 Answers
In the remote there is a circuit .when you press any button on the remote that circuit recevies the signal and it functions.on the circuit if any dust gets collected .then many a times the remotes stops functioning.just open the remote control with the proper screw driver and inside there will be a rubber pad of buttons .if that pad is little bit moved then also this happens.just remove the pad then clea the green colour circuit in the remote with a tissue paper and then again adjust the rubber pad and check out .mostly it will work properly.but if that does not solve the problem.then the another fault is the battery in the remote that may have turned weak.replace the battery and also check out.if still the problem.then its confirmed that remote control is faulty.get it replaced.
  • 15,935 Answers
If all the buttons on the remote are working, the drive motor for the volume on the reciever has failed.
A repair of this nature is advanced, and without knowing your skillset, i cannot make the judgement on whether or not you can make the repair.
Some are direct drive, others are band. If the problem was intemittant, the band may need adjustment.
A local service center may charge 1 hour labor plus parts (if required) to do the job correctly.
Thank you for using FixYa - a FixYa (accept) rating is appreciated!
  • 129 Answers
It should be the remote which has gone wrong. The buttons might have weared out and are no more creating a contact. Look at replacing the remote or getting it to a technician who can probably, dissemble it and reinstall the weared out components.
Thanks
    Sergeant:
  • 326 Answers
Its the remote control problem.the inter circuit on the remote is turned faulty.or may be it can be due to moisture collected on the circuit.open the remote and clean the inter nal circuit and try .
  • 679 Answers
Volume buttone might be not working due to some internal damage.
  • rockfixya
    rockfixya Feb 03, 2009
    and now the remote is gone due to some short circuit in remote.
    you need to purchase a new remote,
    purchase it from>>
    http://www.google.com/products?client=op...
    Thanks for using fixya
  • rockfixya
    rockfixya Feb 05, 2009
    There are already cheap remotes $29 apx. It’s better to buy a new remote instead of repair old one.Thanks
  • 153 Answers
Only the remote wil be gone
check the remote
  • nicra7 Feb 03, 2009
    remove the remote and see if u can fix it
    check the circuit
    mostly dust would be formed clean it and use it then it wil be fine
Sony rm ss251
As all other buttons works properly except Volum Dn, the problem is with the remote control itself. Clean the remote control and check. To clean it, you have to open the remote control. If it too doesn't help you, buy one original remote control from the authorized service center for Sony. No universal remote control will go properly with Sony TVs. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Sony Televison & Video
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Aug 15, 2012 | Sony Televison & Video
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
I need this remote control RM-PP404. Do you sell these?
Did you try a search engine for it? They're everywhere. Check eBay.
We are advisors. No products.
Aug 08, 2011 | Audio Players & Recorders
I really like my Sony Ericsson 608i phone for work but lately when I'm talking on the phone, the volume of the microphone seems to be very low as the person I'm talking to can hardly hear me. I had a new...
hello my friend,
when you make a call try to check first the volume at the side of your cellphone... if it is already full volume and its still the same... maybe the microphone of your cellphone is already weak and in need of replacement...
Feb 02, 2011 | Sony Ericsson K608i Cellular Phone
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
My remote control does not work suddenly
Try installing new batteries such as Duracell batteries. Make sure they are installed properly in the remote with positive to positive nodes and negative to negative node. If you own a digital camera, you can test the remote to see if it is working. Point remote at camera (powered on) and press a button on the remote. If you see a blue / purple light on the remote's led, then the remote is working. If not, then the remote is probably broken and you need to buy a new one.
Aug 09, 2010 | Sony RM-PP404 Remote Control
Our sony remote's volume buttons do not work. Can it be fixed
you can open it and clean the board and the buttons
with pure alcohol
Apr 07, 2010 | Sony RM-V310 Remote Control
Televison & Video Logo
118 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
