Question about IBM 4247 A00 Matrix Printer
Cuts off the top of the letters
Just replaced the printhead still have same problem
    Problem Solver:
  • 8 Answers
Clean all optical sensors and find the one on the left hand side of carriage, just under the ribbon left side, you will see a little silver plate covering a BLACK sensor. Use compressed air to blow out the paper dust. Then on the maintenance menu #11 CALIBRATE the sensors. Power off, power on and test
If this does not clear the error, you will have to replace the sensor HARNESS, the harness has 5 sensors attached to one connector, so if you are not mechanically inclined, i would suggest sending the printer to www.lhsjrinc.services.officelive,com.
Posted on May 07, 2009
IBM proprinter 4210 letters have a white line in the middle of the letter - is that a print head problem and can that be replaced. We changed the ribbon and it still occurs
If it's not the ribbon, then it would most likely be the printhead assuming there's nothing else blocking the printhead or ribbon.
Feb 03, 2011 | IBM Proprinter II Matrix
It prints improperly, dark on top then fades to nothing.
Here are the steps.
1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
a.Lift the printer access door, then remove the ink cartridges from the printhead
b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
2.Clean the printhead.
a.On your computer, open your Kodak AiO Home Center software.
b.Click on the Help (?) button.
c.Click on the Maintenance option.
d.Click on the Clean Printhead option.
3.Print Demo Page.
Press Scan and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
If issue persists,the printhead on your printer requires replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print has line through letters
Your printhead is shot time to replace it
the part number for the printhead for the ML320 is
50063802
you can get a new head for around $100
or a refurb for around $55
Feb 18, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
On some lines the letters are cut in half and not lined up
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
How do I clean the printer heads for the HP K550
1. Remove printhead for offending color.
2. Soak printhead area in 1/4" of warm water for about one minute.
3. With a dry paper towel lightly wipe the printhead length wise.
You should get two continuous color bands either black/yellow
or cyan/magenta.
4. Repeat steps 2 & 3 until you get two continuous color bands.
5. Replace printhead in printer print several blocks of each color.
6. Repeat from step 1 until it works.
7. all else replace printhead.
Jan 13, 2009 | HP OfficeJet Pro k550 Printer
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing the top of the characters
Yes quite possible pin broke on head, check ribbon is fitted correctly and has plastic sheild on front of it intact
Jan 18, 2008 | OKI MICROLINE ML-395 Matrix Printer
Tops of letters are cut off when printing.
This is usually caused by clogged or burned out printhead nozzels. You can try putting the unit through a couple cleaning cycles. If that does not help, then replace the cartridge with a new HP BRAND cartridge. Do not trust refilled or compatible cartridges in this case. The heating elements in the individual nozzels can burn out causing your type of problem. Let me know one way or the other Ed
May 30, 2007 | HP PSC 1610 All-In-One InkJet Printer
Oki 520 missing print
You have replaced the item which is commonly the cause- the printhead. The other possible problems are: a connection break in the printhead ribbon cable, which makes electrical connection from the driver circuitry to the printhead. Look for a tiny crack, especially along the edge of this ribbon cable. Another possibility is an electronic component defect in the circuitry which fires the printhead, or maybe a loose solder connection in the same circuit. Lastly, when you replaced the printhead, are you reasonably certain the replacement head didn't have a broken top pin or two?
Apr 10, 2007 | OKI MICROLINE 520 Matrix Printer
IBM 4247 A00 Matrix Printer Logo
111 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
