Question about Sharp 32L-S400 32" TV
Sharp 32L-S400 Parental Programing
Someone somewhere has programed a code into the Parental Programing. I would like to begin using this feature but I am unable to do so. Can you assist me in reprograming the Parental programing number so that I can start using it. I need to be able to put in a NEW number. Thank you
  • rachele12345 Nov 13, 2008
    my problem is the same ,as in just married. it appears all channels have been blocked. Ehen i go into menu and to parental control it tells me i need a secret code. that is the only option.
  • 3 Answers
There are two ways to solve this problem 1 enter menu and remove old code and replace with new one, 2 reprogram eprom
Posted on Aug 07, 2007
SOURCE:
No sound
tried to hooked up using only an air antenna if you can get good picture and sound. if you can get good reception then the problem not the tv.
Jul 21, 2012 | Sharp 32L-S400 32" TV
Sharp TV Model 32L-S400B - Reprogram Channels
Download the user manual to your Sharp TV by this link. It will ahve all details. OK?
May 21, 2012 | Sharp 32L-S400 32" TV
SHARP 32L-S400B SHEARED OFF CABLE CONNECTOR FROM INSIDE TV TO CABLE .CAN IT BE REPAIRED INEXPENSIVELY?
I have the same problem. Do not have any idea on how to fix it without probable major expense. I have to connect cable box to RCA inputs which require the dvd player to connect with the front inputs...very inconvenient! Hope someone has an answer to this problem.
Sep 04, 2010 | Sharp 32L-S400 32" TV
My sharp 32L-s400b will shut off after it warms up and will not come back on until unplugged for a short while to cool down
What I can think of is either the main filter capacitor is dried up, I had a set that would stay powered on til it warmed up then shut off and the main filter cap was the problem. Or the tv could have a thermally induced shut down, or the circuit protection kicks in due to excessive voltage. A component is defective and excess voltage is happening and the tv shuts down to prevent excessive X-ray emissions or damage to other components. You should open up the tv, be very careful and if you don't feel comfortable, have someone with more experiance or a shop look at it. Look for any blown or burnt components. Also listen for any weird or funny noises inside the set.
Mar 12, 2010 | Sharp 32L-S400 32" TV
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
Sep 06, 2008 | Sharp 19R-M100 19" TV
TV Turns Off
Good day.
Yuor TV has an issue particularly in the power supply section with regards to the loose components. This issue can be best addressed by having your units' circuitry be resoldered before it could damage some parts.
Response is higly appreciated.
chris
Jan 11, 2008 | Sharp 32L-S400 32" TV
Sharp tv
u need to reprogram your eprom files are corrupted
Aug 06, 2007 | Sharp 32L-S400 32" TV
Sharp 32l
hi hope u didnt touch enything in there 30,000V is what you get.... after 3 days it will dissolves anyway you can replace it but you'll need your solder experience in hand you need to buy a new unit a good soldering iron and make them small round and neat good luck
Mar 27, 2006 | Sharp 32L-S400 32" TV
Sharp 32L-S400 32" TV Logo
112 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
