Question about Zebra TLP 2844-Z Thermal Label Printer
Config page How do I print a configuration page sio as to to check to see what, if any, IP address has been assigned to this printer ? Thanks, Bill
  • 13 Answers
There is no CONFIG page but there is a setup sheet that will print on how the printer is setup. when the unit is on press & hold the Button till it BLINKS 1 time only. Here is the button sequences. Config page - 9a182e0.jpg
Posted on Feb 05, 2009
  • Stephen Clouthier
    Stephen Clouthier Feb 06, 2009
    Please don't forget to rate this possible solution or add comments to whether or not it worked.
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
How can you print the Configuration Page on a Canon 3220? We are trying to find out what the IP address of the printer is.
For a Canon C3220:
- Choose the Printer tab on the touch screen - Under Printer Status, go to Settings - Go to Functions - Go to Print Pages - Select Configuration
The configuration page will print out. Thanks for using FixYa!
For configuration page instructions on other copiers, printers, and fax machines, check out the How to print config pages blog.
May 03, 2011 | Canon imageRUNNER C3220 Color Copier
I have an HP Lasejet 1320 printer and I am trying to reset static IP Address as we are moving from one network to another. I need to know how I can determine the mac address of the printer as I can...
To find the static IP and Mac Address of your printer, press and hold green button for 10 seconds until green and yellow light starts blinking together, it will take out 3 print outs, 1 is printer information, 2nd will be configuration page, 3rd will be the toner status page,
Also you can Check your printer manual. This is the easiest and fastest way to find the printer's MAC address
Alternatively Print out a configuration page.
If you require more assistance, feel free to reply to this post
Thanks for Asking FixYA!
Regards, BA
Feb 08, 2011 | HP LaserJet 1320 Printer
I don' t know de printer' s ip address. how I can learn it? the printer is tallygenicom 8008
You can print a configuration page this will show you the current IP Address set in the printer, this Can be printed in the follwoign way;
  • Place printer OFFLINE
  • Press MENU / ENTER button
  • The display should read TEST MENU (if it does not press > repeatedly until it does)
  • Press > until CONFIG PAGE is seen.
The printer will print out a configuration page this will show the network settings
Dec 01, 2010 | TallyGenicom 8008 Laser Printer
I want to connect my SCX 4500w to a new network (wireless). when i try to use a web page to configure the printer settings it doesn't response... I check the IP and write in in my Internet Explorer,...
You could try having your Samsung SCX-4500 print out a network configuration sheet. It will have the printer's IP address, default gateway etc.:
1) Press the <Menu> button on your printer panel
2) Scroll using the (<) or (>) navigational arrows until "Network" is displayed
3) Press the <OK> button
4) Scroll using the (<) or (>) navigational arrows until "Network Info" is displayed
5) Press the <OK> button
Your printer should print out a network configuration sheet. The IP of the printer appears in the TCP/IP information on this configuration sheet.
Note: Your printer's IP assignment should be "Static" not "DHCP" (You may skip the following steps if your printer's IP assignment is already "Static")
To change your IP assignment from DHCP to Static:
1) Open up your Windows browser
2) Type in the printer's IP address in the address (location) bar of your browser:
Example: http://192.160.0.100 (use the real IP you found above from the network information sheet)
3) SyncThru should load - Click "Network Admin" or "Network Settings"
4) Click on the "TCP/IP" option on the left side
5) Change the IP address METHOD to "Static"
6) Click <Apply>, then <OK> or <Exit>
Now your printer is ready to be added to your network. You have the information you need from your network configuration sheet. Your install should now proceed smoothly.
I hope this information was helpful!
Mar 07, 2010 | Samsung SCX-4500 Laser Printer
HP laserjet 2015dn IP address problem
please do not assign dynamic IP on the network printer. give a static IP on it base on your network config. and also, please do assign all you computers on the network with static IP's so that every time they boot there will be no IP conflict or problem on the network connection.
Mar 05, 2010 | HP LaserJet P2015dn Printer
Wireless printer
  1. Print a Network Configuration Page from the product.
  2. On the front panel of the product, press Setup .
  3. Press the arrow buttons to select Network and then press OK .
  4. Press the arrow buttons to select Network Settings and then press OK .
  5. Press the arrow buttons to select Network Configuration page and then press OK . NOTE: If the page does not print, unplug the power cable from the back of the product, wait a few seconds and then plug it back in. Repeat the previous steps, a-d, to print the configuration page.
  6. Change the IP settings to Manual from the printer:
  7. On the front panel of the product, press Setup .
  8. Press the arrow buttons to select Network and then press OK .
  9. Press the arrow buttons to select Advanced Settings and then press OK .
  10. Press the arrow buttons to select IP Settings and then press OK .
  11. Press the arrow buttons to select Manual and then press OK .
    1. Set the IP settings from the Manual IP Settings Menu using the following instructions:
      For this item...
    Do the following: IP Address Type in a static IP address on the same subnet. Select an IP address outside of the Dynamic Host Configuration Protocol (DHCP) range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway
  • tahnks
    TTYAGI
    Apr 30, 2009 | HP DeskJet 6988 Printer
    I need to change the IP address on my hp color laser jet 2840 coud you help me with that
    Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
    When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
    Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
    NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
    1. Print the Configuration page if needed. You will be entering the "current" IP Address.
    2. Open Internet Explorer. Delete EVERYTHING from the Address line.
    3. Enter the IP Address in the Address line and press Enter.
    4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
      NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
    5. Type 1: Click the Networking tab.
      Type 2: Click the Administration button. Click the Configuration tab.
    6. Edit the IP address, Subnet Mask, and Gateway as needed.
    7. Do not change any other fields.
    8. Scroll to the bottom and click Apply. Click OK.
    9. Close Internet Explorer.
    10. Restart the Printer. Print the Configuration page to see if number was set.
    NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
    1. Go to this HP Support Page.
      Configuring TCP/IP through the Front Control Panel
    2. Click the link to your printer model. Highlight these steps.
    3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
      Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
    4. Follow the steps from the printout to assign the desired IP Address to the printer.
      IP address will be entered at the IP BYTE prompt
      Subnet mask is entered at SM BYTE prompt
      Gateway address is entered at GW BYTE prompt
      Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
    5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
    Hope this helps
    Chris (ziraffa)
    Jan 09, 2009 | HP LaserJet 2840 Printer
    How do I set the IP address on my HP 8150
    1. Launch your web browser.
    2. In the Address: or Go to: field, type the IP address assigned to the
    printer (for example: http://192.168.1.1) or the host name (for example:
    http://myprinter).
    If you do not know the IP address for the printer, it is listed on the
    printer configuration page under Protocol Information in the TCP/IP
    section.
    To print a configuration page:
    a. On the printer control panel, press Menu until INFORMATION
    MENU displays.
    b. Press Item until PRINT CONFIGURATION displays.
    c. Press Select to print the configuration page. After the process is
    completed, the printer will return to the READY state.
    From there, you can configure the printer using the web GUI. Consult the manual if you need at:
    http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl10150/bpl10150.pdf
    Hope this helps, and have a good weeked.
    Dec 12, 2008 | HP LaserJet 8150 Printer
    HP JetDirect IP Address
    how to assign the IP address to Hp color laserjet 2550Ln printer?
    May 10, 2008 | HP LaserJet 2550Ln Printer
    Zebra TLP 2844-Z Thermal Label Printer Logo
    639 people viewed this question
    Top Zebra Office Equipment & Supplies Experts
    Dave Busselle
    Level 1 Expert
    Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
