Kenwood 6.1 dvd screen won't turn on, but reset button light is still on? Checked fuses and tried resetting it nothing's working
SOURCE: Kenwood DDX 7017 bypass code
During code request mode:
Point the remote control to the screen and input this numbers (from the remote control) as faster as you can 55222277
You will not see any change on the screen until you enter the last number.
This will clear the code
If you make a mistake,just reset the unit and start from the top.
Thank you for rating
SOURCE: kenwood ddx-6019 password
a friend of mine who is into bypassing stuff...found this method from sumwhere and it worked on my system...
u need to reset the system first by pressing the small button right next to <ATT> using a ball point pen or something pointed...
once it reboots,
keep the <SRC> button pressed till the display goes off, then while keeping the <SRC> button pressed, press the <ATT> button for 3 seconds, while keeping both of these pressed at the same time, press the small <RESET> button next to the <ATT> button using something sharp...
this hard resets the system and it reboots to a blank screen,
press the <SRC> button once and you have all the options working...
anything else, lemme know...
[email protected]
i think you find some softuare on ebay to unlock your radio....i m not 100% sure but you can take a locke
SOURCE: touch screen doesn't work.
The password can be entered by setting the arrow buttons, if u know the password, or get kenwood to give their default password and check that the touch screen is not getting grounded, 'cos that's when it goes apparently, dead...sodeep
SOURCE: kenwood kvt-815 dvd touch screen not working
did you ever find a solution for this problem, I am currently experiencing the same thing
