Question about Fellowes 3011001 Shredder
Fellows Shredding Machine Model 5B-97C
Machine is not shuting itself off when shredding job is completed. Actually we always have to shut the machine off ourselves. No longer shuting itself off. I have cleaned two glass small 'eyes' inside machine at the top. This has not helped.
fellowesrep
  • 102 Answers
SOURCE: Fellows ps60c-2
this was probally caused by a jam forcing cutters apart and breaking housing inside.
Posted on Apr 01, 2008
SOURCE: Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Posted on Jul 11, 2008
SOURCE: Fellows Powershred OS-11Cs - not working
It's just the (On and Off) switch not working properly (loose contact). Try to disassemble it and take a look if it's in the center location to make contact with On or Off positions.
Posted on Sep 19, 2008
haystack11
  • 55 Answers
SOURCE: we have a Fellowes Powershred C-220C and the
Only if you are mechanically handy and know how to take a part. Most of these shredder's sensors are PLASTIC and break EASILY. I should know, I had to take apart my wife's shredder.
I had to bypass the sensor and rewire it. It can be done if you know what you are doing. If not, don't try it
In your case I would unscrew the top assembly. Than I would use a can of canned air to clean out the sensor eye. Than I would use tweezers to pull out all specks of paper I could find.
Your best bet is to try to return it for a replacement.
Posted on Sep 24, 2009
Testimonial: "Thanks! I will see if our janitor can fix it Bev"
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
How do I fix thread breaking and shredding on a Janome mb 4
If upper thread is actually shredding, change the needle. Verify the needle is compatible with the thread and fabric you are sewing. Thread that is too large for the needle eye will shred.
All About Needles
Feb 27, 2017 | Janome Sewing Machines
Omnitech wont shred papers.
Sounds like its jammed? Have a really close look for staples, paperclips etc stuck in the drive gears or blades
May 19, 2015 | Office Equipment & Supplies
Samsung washer tub is shredding. Top load model WA400PJHDWR/AA. Was making terrible noise when spinning and when I opened it, bits of plastic were everywhere. Looks like top of tub is rubbing against...
best thing to do is call the store where it came from and let them replace it with one just like it or exchange it with one around the same price
Oct 02, 2013 | Samsung Washing Machines
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
THE SHREDDER ISNT SHREDDING ANYTHING ANYMORE, the power still runs and it will still take the paper but its not shredding anymore???
You wil need to Have the shredding head rebuilt or replaced. and or a new machine. A new head is very expensive. Here is the number for fellows 800-955-0959. Check on parts if they are still available. Hope this helps your friendly service tech (colorado).
May 06, 2010 | Fellowes Powershred 220 Shredder
Fellows T7CM Shredder
Make sure you remove all five screws--there's one hidden under the sticker on the underside of the shredding unit.
Mar 13, 2010 | Fellowes Office Equipment & Supplies
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Sep 09, 2008 | Fellowes 3011001 Shredder
Shredder shuts off when shredding, and runs continuely when running
take a q-tip and clean the eyes, if that doesn't work you may have baad eyes or a bad board.
May 09, 2008 | Office Equipment & Supplies
Fellowes 3011001 Shredder Logo
88 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
