Question about Microsoft Zune JS8-00001 Digital Media Player
Zune 8GB - Won't turn off
My 8GB Zune player won't power off for more than a few secs before the main menu pops back up. The back button doesn't seem to be responding either so I can't reset the device as recommended to fix most problems. I can select from the main menu, but once in a selection I can't go back. What can I do to fix the problem.
  • Shroud365 Feb 11, 2009
    I Have ALMOST The Same Problem, My Zune Back Button Doesn't Work Anymore, It Was After My Update to 3.0
    Help !
  • Anonymous Mar 12, 2009
    I'm having the same problem. Back button does not work and the Zune turns on automatically seconds after I turn it off. I must locked the Zune after turning it off.
  • 38 Answers
Warranty activated yet? Get it done. Then create a Repair Order online, or call Zune support at 1-877-438-9863, if you dare.
That is your best bet. Y'all got mechanical problems and nuthin ain't gonna help that in FixYa. Sorry, chum
Posted on Mar 10, 2009
Zeki 10" tablet won't load
Hi, Is your Zeki fully charged? My suggestion is to hold the on/off button for a few secs. to fully power down. Put it on the charge and let it fully charge before trying it again. Then try turn it on again.
Feb 18, 2013 | Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream...
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
I have a 8GB zune. i thinks its older i got it a long time ago but i have never been able to turn it on!! wat do i do?
First plug it into the charger. Then take it off of hold. Finally hold the back or power button until it turns on. ;)
Mar 04, 2011 | Microsoft Zune JS8-00001 Digital Media...
My Zune HD won`t turn on, what do i do ? =]
Hold the power button for 10 seconds. this should cause reset. if it does not hold it again for 15 seconds this should cause it to power into repair mode where you will then need to plug it into your computer and update the firmware with the included software. hope this helps!
Apr 15, 2010 | Microsoft Zune HD MP3 Player
I cant seem to turn off my zune completely, only pauses the unit, the screen goes black after holding the pause button, it appears to be off, then i go to use it hours later and the battery life has...
The Zune never really turns off completely. To turn it off, hold the back button and up on the Zune pad. As soon as the screen turns black, let it go, and turn on Hold.
This will turn it off completely.
Mar 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
8gb zune ''back'' button does not work
the set needs to be oped and have switches checked, one of the switch is holding down a connection of power.
also check the reguration of that set,
pause switch is cascaded in series with the many switch.
plse try that
Mar 18, 2009 | Microsoft Zune JS8-00001 Digital Media...
8gb pink zune
try restarting it. the process should be in your paper menu thing that you got with your zune(for future reference). press hold and the back button. http://support.microsoft.com/kb/946064 that is the website if you need a diagram of which buttons. good luck! please rate! =]
Dec 28, 2008 | Microsoft Zune JS8-00001 Digital Media...
Reseting my zune
Try to reset it. Press the back button (<-) and the up button ( above the Enter key) simultaneously. If this doesnt work, continue to press the back button with other directional buttons to see if this gives you a result.
Sep 09, 2008 | Microsoft Zune 2nd Generation Digital...
Zune won't turn on or charge
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 11, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
368 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
