Watches Logo
Posted on Feb 03, 2009
I received a HangWare digital watch (circa 1995 +/-) as a gift for hiking but they no longer had the owners manual. How do I set the time/functions with the four button positions? Or, does anyone have a copy of the manual they can send? Thanks for ANY help you may be able to give. Ryan
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
240
Points
See if these instructions for a generic 4-button watch help:
https://dakota.webfeatsecurity.com/PDF_FILES/Digital.pdf
I was able to reset the time for my HangWare Jungle watch with these instructions.
Waveceptor reset
I have a number of these Casio and Citizen watches. This watch does not use GPS for the time keeping. It uses a land based broadcast time signal. There is public information about where the signals come from for your area. The technical breakdown of the time code signal is public access information.
The instruction manual of the watch has the information about when your watch should automatically receive the time signal, and how to set up the watch. Many of the manuals also included a map showing the time signal coverage, and includes the time of day information to show when the signal is strongest.
Make sure the watch settings are for your time zone. This is important. If the main time zone is not for your area it will be trying to receive the signal at the wrong frequency at the wrong time of day. There are areas where the signal may not be able to be received. You can get the mapping for this from the service that the watch has been set to use.
In North America the auto time receive is supposed to take place between midnight 00:00 to 04:00. In the eastern part of North America the reception is poor compared to central and western part of North America. Check the instruction manual for your watch for details.
Below is the spec listing of your watch.
  • Atomic Timekeeping
    Receives time calibration radio signals which keep the displayed time accurate
    Auto receive function (3 times per day)
    Manual receive function
    Signal: WWVB, UK MSF Frequency: 60kHz
  • 50M Water Resistant
  • EL Backlight with Afterglow
  • World Time
    29 times zones (30 cities), city code display, daylight saving auto/on/off
  • Date Alert
    Display flashes when set date is reached
  • 4 Daily Alarms and 1 Snooze Alarm
  • 1/100 second digital stopwatch
    Measuring capacity: 99:59'59.99"
    Measuring modes: Elapsed time, lap time, split time, 1st-2nd place times
  • Hourly Time Signal
  • Auto Calendar (pre-programmed until the year 2039)
  • 12/24 Hour Formats
  • Accuracy: +/-20 seconds per month (with no signal calibration)
  • Battery CR1620
  • Approx. battery life: 2 years
  • Module 2556
Size of case / total weight
WV57 47.0 x 39.0 x 12.5mm / 44g
WV57HD 47.0 x 39.0 x 12.5mm / 89g
Look can someone help me set the digital time on my watch please its omega seamaster polaris cheers....
Your watch uses a calibre 1665 movement. You might contact After Sales Service and ask them if they would send you an owners manual. Setting the time and date is fairly straight forward but you also need to sync the analog and digital displays so it is a bit difficult to describe in just a few words.
The basic guideline is
To select function - turn the crown
To change function - pull out the crown and then turn it
To start and stop functions - press the crown
Dec 01, 2012 • Watches
1helpful
Need owners manual for Pulsar PQ2001 Digital Watch
I don't know if the offer is still good after two years, but take a look here.If you just want to set the time, look here.
Apr 10, 2012 • Watches
I don't know whether the offer is still good after two years, but take a look at this thread.If you just need to know how to set the time, look here.
I received a Sharp Remote Control Watch as a gift but it has no instruction manual. I am unable to set the time properly and would appreciate some help in getting the watch set up.
I would love to help with this problem...but I need to know the Model of the watch first. They perhaps I can give you detailed instructions on how to set it.
Thanks,
Sandy
Apr 11, 2011 • Watches
1helpful
The columbia site has no timing instructions.
Instructions can be obtained by going to the Columbia web site "columbia.com".
Insert "watches" in the search box (top right) and the next page shows a watch with the title "timing" and underneath in says "PDF instruction manual for watches"
Click on this and a list of diagrams for the watches appears. Choose the one that is for your watch and down load.
No manual how do I set time?
You have to open caseback and upload the movement number here. Then I might help.
Versace flc99d001s099
good after noon,to set the time and is depend on the model of your watch,if your watch is analog use the crown to set the time and date just pull the crown slowly and wind it,but if your watch is digital use the button to set the time,thank you !....
8helpful
Analog will not sync with digital
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Regards,
Tahir Khan
Feb 14, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
