Question about ATI T550PRO TV TUNER PCI W/REMOTE CONTROLLER,16MB, MCE CERTIFIED&AM/FM (OEM) (VCT550PROTV)
My wireless remote is not connected to my computer
Please can you tell me how to connect my wireless remote control to my computer the model name is
REM 05 MCE RF remote controller
Are you running the MCE version of XP and is it installed? Look for c:\Windows\eHome directory. If you find that directory, then you should have MCE installed and running. If not, you need to get and install the MCE version of XP. Then look here for further information to getting your remote to work with the MCE.
Help Installing a Remote Control in MCE
I hope this helps?
Posted on Feb 03, 2009
Amazon kindle registration
Just a few questions.
is your computer connected to the internet with a wireless connection, or with a cable? Is the internet connection you see on the kindle, the name of your wireless router? Did you setup the wireless connection on your kindle, using your connection name (the name you gave in on the wireless router you own) and password.
If you answered one or more of these questions with a no, first solve or change that. When you don't have the answer, because you don't know, you have to asume it is a no.
please tell us you did setup the wireless connection correct, so I can look to other possibilities.
Aug 02, 2014 | Amazon Kindle Fire HD
Tip
Configure Wireless Zero Configuration to configure wireless connection on XP...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on Mar 18, 2010 | Computers & Internet
D-Link router switches off internet connection when tv/DVD remote is used
Hi, Your question is not so clear. For giving the proper solution I need to know something. As per my knowledge a fiber optic cable doesn't connect a router directly without a Media Converter. Secondly please tell me the model number and the brand name of your television. Third do you configure your internet connection on your television through IP address??
Jun 06, 2012 | D-Link DIR-300 Wireless Router
I got wireless hooked up but it wont connect & it just tells me its scanning.
Hello
more information is needed to answer your problem.
Is this a laptop? Brand and model please? Also do you have a wireless router in the house? Has anything been done to it yet?
Do you know the name of the network you should be connecting to?
Jun 01, 2010 | Computers & Internet
My computer has stopped connecting to my netgear dg834pn router even though my mums is still working so it must be my computer. I have lost the disc to install. please help
HI, Follow the steps below to configure your computer for wireless connection:
If your computer has windows XP then perform the steps below:
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista, perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 27, 2009 | NetGear DG834PN Router (DG834PNAU)
Hello. My NetGear wireless adapter is installed and the hardware manager says it's installed properly. The signal strength is fine (I have a Mac, too, with Airport card that works fine). Yet, it tells me...
Hi, follow the steps below to configure settings on the concerned computer:
4. Change the Start Up Type to Automatic and click on Apply.
8. Go to the 'Wireless Networks' tab.
3. Click on the 'wireless network' astab.
7. Highlight thee SSID from the list that you want to connect to.
9. You should have successfully established a wireless network connection.
Regards
Anand
Sep 23, 2009 | NetGear (IM-WG511T) Wireless Adapter
My computer is picking up a wireless signal but will not connect to internet
Hi, first make sure that you can go online with a wired connection through the router. If no, then you will have to reconfigure your router and if yes then please perform the steps below to configure settings on the wireless computer:
If the computer has VISTA :
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
If the computer has XP:
You can visit the link below to follow the steps in case the issue occurs again:
Sep 21, 2009 | Computers & Internet
Will not connect to the wifi modem
If the computer has windows XP then perform the steps below:
Perform the task below on the wireless VISTA computer:
Regards
Anand
Sep 13, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computer interfacing
You have a computer (what manufacturer and model?) connected to a Netgear WGR614 wireless router (please confirm the router manufacturer and model) by wire or wireless?
If the computer is connected wireless is it with a wireless adapter built into the computer or added to the computer?
If it was added to the computer what is the manuracturer's name and model of the add-on device?
Has any other computer ever successfully connected to the internet using your router?
  • If so was the computer connected using a wire, if possible?
  • If so was the computer connected wirelessly?
If no computers were connected successfully to the router please provide the name of your internet service provider?
I also may need to know the city and state you are located in or other information. We probably need to configure the router to attach to your internet service providers equipment
The following are to determine if the internet service providers equipment has been successfully installed and the capabilities of that equipment as it may support connecting your router, if necessary, and your computer to the internet.
Were any computers ever successfully connected to the internet by directly connecting to your internet service providers hardware?
If yes how were they connected
  • USB cable?
  • Ethernet Cable?
  • Wireless?
  • If wireless what is the manufacturer and model of the internet serivce providers hardware providing the wireless service?
Dec 16, 2007 | NetGear WGR614 Wireless Router
Internet connection not working
I have ATT DSL too.
Mine came with a Seimens SpeedStream 4100 ethernet ADSL modem. Did yours?
If not what is the manufacturer and model of the unit ATT sent?
Is it hooked up and working? If so continue.
IF you have a Seimens SpeedStream 4100 --
  • It has 3 connection on the back
  • one for power
  • one for a phone line (gray in my case)
  • with a separate gray cable
  • this is connected to the non phone side of a splitter
  • one for an ethernet (yellow in my case)
  • with a separete yellow cable
  • this may be loose to connect to your computer OR
  • connected to another device
  • IF connected to another device what is the manufacturers name and model for that device.
If ATT supplied a device other than a Seimens SpeedStream 4100
  • Is there anything other than a power adapter and a phone line attached to that unit now?
  • What is the manufacturers name and model for that device.
In terms of your ATT DSL service
  • How many devices do you intend to connect? Computers, game consoles, etc
  • How many connected by wire, if you know?
  • How many connected by wireless, if you know?
To you know if your DV4000 computer
  • has an ethernet connector?
  • has a wireless network adapter built-in?
  • IF not can can you look on the label on the bottom of your computer and tell me the full model number is. Please use this Model Link to help figure that out.
Do you have any devices such as a router, wireless router, wireless access point either already connected or to connect to your ATT DSL service?
Please identify the manufacturers name and model number for each device and whether or not it is connected and working.
With all the above I will know where to begin in the process of attaching your new computer to your ATT DSL service. Please add a comment to this issue with the necessary information -- I know it will be long. However you are the hands and eyes of this team and my questions are to get you to tell me things I would know if I was present and installing these devices.
Dec 16, 2007 | HP Pavilion dv4000 Notebook
Televison & Video Logo
121 people viewed this question
Top ATI Televison & Video Experts
Are you an ATI Televison and Video Expert? Answer questions, earn points and help others
