Question about IBM NetVista PC Desktop
What motherboard to use?
I have a very small, IBM Netvista case an am looking for a motherboard. the motherboard size must be limited to 8.5 inch. x 9.5 inch. All the outside connections are along the 9.5 inch side. I have not been able to find a motherboard to fit. Also the power supply is only 200 watts. the model # for this case is H32-HS clas SU
  • jad54 Feb 05, 2009
    Thanks jabba316! I think this may solve my problem. Wish me luck, Jim
  • jad54 Feb 06, 2009
    Thanks for the info, i will follow up!
  • 326 Answers
You could get a Mini-ITX mainboard in there, its around 17cm x 17cm,
when you look for motherboards look for ''form factor'' in the specification and google it to try to find the size.
some sizes you will see are
atx
micro-atx (this might fit, not sure on the size)
lpx
nlx
hope it helps
Posted on Feb 05, 2009
  • 1 more comment
  • mark hudson Feb 06, 2009
    dont forget to consider what parts you have or might be buying also when you get your motherboard,
    cpu - what type of processor you have or might be buying
    harddrive - sata or ide
    cdrom/dvdrw - if you have ide, make sure the board has enough ide slots, most new ones only have 1 now which causes a few problems if you have a few ide drives + ide harddrives
    power connection - if you current power supply has the 24 pin + some motherboards need a 4 pin power aswell
    what graphics card you have - agp or pci express
    good luck and reply here if you get stuck so i can assist you
  • mark hudson Feb 17, 2009
    how did you get on with this?
    all sorted i hope :)
  • azureforte Dec 29, 2010
    The actual spec you need are closer to 9 3/4" and 7 3/4" due to the factor of having the metal sleeve for your Hard drive sticks out at bout 8" from the back of the case Since I'm guessing this case is an Old IBM NetVista case that power supply you have 1.25" X 8" X 3.5"? I'm almost looking at having to make a side mounted power supply with my case like that since it's 1. tough to find this this style of power supply and 2. this style has a tendency to burn up more frequently then other power supplies
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
My hard drive is failing on an IBM NetVista 8305. Is there a specific hard drive that needs to be put in to replace the failed one, and where would I find that drive? I've run into compatibility issues...
I've had a quick look a a photo of your motherboard and it looks like it supports both SATA and PATA IDE devices.
Have a look inside the tower, if you current HDD is connected via a fairly broad grey ribbon cable, its using a PATA IDE interface - the older fashioned one.
If its connected with a fairly narrow flat red coloured cable, then its a SATA interface.
Remember to set the jumper settings on your new drive to match those on your old one.
Mar 14, 2010 | IBM NetVista 8305 PC Desktop
Netvista will not bootup
ada tampilan no processor waktu looding
Jan 24, 2010 | IBM NetVista PC Desktop
IBM Netvista MB 49p1599 Front Panel Pinout
1 pw sw
2 pw sw
3 rst
4 rst
5 - pw led
6+ pw led
7+ hdd led
8 - hdd led
<== left 1. . . . . .8
ATX connector ==> right
Mar 07, 2009 | IBM (49P1599) Motherboard
IBM NetVista 6578-RBG Windows XP hanging
It seems, that you should replace motherboard, I've seen this kind of problems in my office, after year or two you won't be able to turn it on at all. In my opinion, it's bad quality capacitor on motherboard.
Any way there is little chance that it cold be bad PSU, but it's really small chance.
Feb 03, 2009 | IBM NetVista PC Desktop
Ibm netvista desktop all in one
You can reset the passwords by removing the small round cmos battery on the motherboard for about 5 seconds. Replace & reboot. Problem should be solved. Hope this helps.
Dec 26, 2008 | IBM NetVista PC Desktop
CMOS Error 0193
The security device plugs into the left front of the MB as viewed from the front. It is approximately 1.5" x 2 inches in size. they sometimes come loose form the socket when a system is moved. Open the case and see if it is there and loose. If completely gone, then you need to contact your MB supplier for either the device, a new board or a factory reprogram of the board to disable the missing device.
Oct 12, 2008 | IBM NetVista PC Desktop
Re:Bios jumper
Your computer is an IBM Netvista 8311.
This link shows ibm netvista 8311 motherboard diagram
www-307.ibm.com/pc/support/site.wss/document....
The cmos reset jumper it is indicated on nr.10, alternatevely when you cannot find reset jumper on a motherboard you can pull out and put back motherboard battery
Best regards
Mar 17, 2008 | IBM NetVista PC Desktop
PC Card
There is a bunch of "model" numbers for the IBM netvista PC. You didn't menton yours in your question but after looking at a dozen or so I'll bet you have at least one PCI slot free for a wireless PCI card.
Jan 02, 2008 | IBM NetVista PC Desktop
IBM Netvista eight beeps wont start
8 beeps means video problem
Try reseating the video adapter
look to see if the fan on video adapter is working if it has one?
Nov 14, 2007 | IBM NetVista X40 PC Desktop
IBM NetVista PC Desktop Logo
151 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
