Question about Brother IntelliFax-2820 Laser Fax
We havet he brother inteli fax 2820. teh paper keeps jamming when it is tryong to feed through. We replaced the drum and we are still having the problem. IT wont feed any paper through without jamming
  • Ray M. May 11, 2010
    if you try one print, where does the paper stop. do you have to remove it through rear door or is it before the drum, in the drum....? reply back and maybe i can help.
    razors
    Champion:
  • 320 Answers
IF YOU ARE HANDY, WHEN YOU OPEN THE FRONT COVER YOU WILL SEE THE FUSER SECTION IT SAYS VERY HOT ON THE COVER IT COMES OUT WITH 2 SCREWS THERE MAY BE PAPER IN SIDE HOLDING DOWN A SENSOR. GOOD LUCK BROTHER SR TECH
Posted on Feb 07, 2009
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother IntelliFax 2820 machine that jams repeatedly. A page or two will come through fine and then the others will all jam. Some just jam in the back of the machine and others get stuck in the...
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Jam paper inside
believe it or not, a bad/faulty drum unit can cause this. or possibly the feed rollers just needing cleaned. it really helps on jam problems when you can print just 1 page and let us know exactly where that paper stops at.
good luck,
razors
Jan 28, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 JAMMED
just clean paper path and clean all roolers and specially paper pick up roller.by mian jee
Dec 15, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jams continue to occur on brother fax 2820
Depends on the location of the jam is. Feed wheels need cleaning, clean with windex. or and most likely you have a bad drum unit,
Jul 28, 2008 | Brother IntelliFax-2820 Laser Fax
Paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
May 03, 2008 | Brother IntelliFax-2820 Laser Fax
Intellifax 2820 plain paper fax
Take it out with the drum unit and make sure the toner is in the drum unit right. If it was ok before you changed the toner then you did something wrong. reinstall the drum and toner after you check it. Lawrence
May 01, 2008 | Brother IntelliFax-2820 Laser Fax
KEEPS FLASHING DOCUMENT JAM!
check these locations carefully
1- where you feed the documents there is a sensor lever to detect a document, look carefully and push on it gently it should go back in place ( spring action)
2-before the drum there should be one
3- there is one in the fuser, YOU MUST look for the sensor usually after a jam a piece of paper is torn off and left on the sensor ( hopefully it was not broken off)
Jan 12, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
265 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
