Question about Kodak EasyShare CX7430 Digital Camera
I cannot get pictures on memeroy disc
I cannot get the pictures to come on memory disc when trying to put the card on my computer
  • Anonymous Feb 08, 2009
    I cannot get pictures on memory disk to load on my computer, or printer.
    Should I install the softwear again. I miss putting my pictures on the
    computer,
The ram couldn't formatted
Posted on Feb 17, 2009
Took about 10 pictures today without realizing disc wasn't in camera. How can I get them on disc to print or send emails?
How do you normally download your pictures?
If you do it by connecting your camera to your computer, simply remove your memory card before making the connection. If you do it by putting your memory card into a card reader, first use the "Copy to Card" command in the playback menu to copy the pictures from the camera to the memory card.
Sep 27, 2013 | Samsung Washing Machines
How do I format a memory card without erasing pictures already on it?
No, format will erase all data. Try doing chkdsk <drive letter> /f in the command prompt.
Dec 22, 2012 | SanDisk 4GB Secure Digital High Capacity...
I put a memeroy card in the camera and it says card protected. what does that mean and what do i do?
The memory cards have a lever on one side by which it can be protected. All you need to do is to take out the memory card and switch the lever on the left side to the unlock position and try again.
Jan 18, 2011 | Cameras
I added a 2gh memeroy card and don't know if it has to be formatted to the camera or do i just start shooting photo's and it will automatically go on the card?
Yes format your memory card for sure I'm also sending a diagram of an SD card showing the little switch on the side. This switch locks the card from formatting to protect or save images.
Also the formatting of the memory card allows the camera and memory card to communicate properly between the two. Formatting should be done after each time you download pictures to the computer Formatting should be done in the camera the memory card is being used in not the computer.
Here is the diagram.
Jan 14, 2011 | Polaroid a540 Digital Camera
I took my memeroy card out of my Nokia 5800 xpressmusic, and now I can not access my memory card, please can you help, Cheers Paul
TRY TURN OFF THE PHONE,INSERT THE MEMORY CARD.....IF NOTHING HAPPENS,REFORMAT YOUR CARD......INSERT IT AGAIN.
IF NOTHING HAPPEN STILL,BUY A NEW CARD IT IS CORRUPTED.
Sep 22, 2010 | Nokia 5800 XpressMusic Smartphone
How do i put my pictures into the computer?
The easiest way to get your pictures into the computer is to use a memory card reader (many computers have them built in). If you do not have a memory card reader built in, an inexpensive reader that reads MemoryStick (the type of memory card used by Sony) is available for around $20.
Once you have attached the reader and placed the MemoryStick in the reader, it will appear as another disc drive on your computer and you can copy the pictures by dragging the files to your current disc drive.
Hope that helps,
BAX
Feb 14, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Says memory card full
Hello. If your memory card is full it's time to transfer some of your pictures to a computer or put them on a cd or dvd disc.if you have the cables to conect to a computer plug the camera into the computer and then turn the camera on. Depending on your operating system your computer may or may not see your camera.If it does you may see a window asking what you want to do , just read through and make your choice.If it doesn't right click the My Computer icon and see if it shows up there as a removable device if so try to open it,from there you can move pictures around to folders on the computer. If your computer doesn't find your camera at all you may need software from the camera company ,if you have a disc install it ,if you don't check the manufacturers web site for software.If the computer doesn,t work out most photo finishing stores can copy the pictures to a disc freeing up space on your card for more pictures.
builderdale
Jan 16, 2010 | General Electric A835 Digital Camera
Getting a memory card error in camera using Kingston SD4/4GB
first of try your memory card by putting it in a card reader device and connect to the computer check wether it is reading or not and if it is working try to copy some image files to that and put back in the camera and check wether it is working if your camera have an in built formating option do that also so memeroy card will get detected by your camera some times if you put cards in other devices first they will ask to format the according to the devices onceits done then no problem if the problem is still there contact your camera supplier and memory card supplier sometimes in side cards there may be internal circutary breakage occurs
Oct 18, 2009 | Kingston 4GB Secure Digital High Capacity...
How do I transfer pictures "from" my computer "to" my Scan Disc?
Some computers have a card slot built in the front of there case,if not, you need a usb card reader. They are very cheap. You put the card into the reader,plug the reader into a usb port and windows
will open the card as a folder. It is used just like a hard drive, you can copy and paste or just drag something into the folder that is
your sd card.
http://www.walmart.com/catalog/product.do?product_id=10038332
You can also get a reader that can handle several different kinds of cards.
Apr 08, 2009 | SanDisk 2GB microSD Memory Card
Kodak EasyShare CX7430 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
