Question about Broan-NuTone Broan Range Hoods Allure II Series - 36'' Range Hood - QS236
42" Allure II Broan Range Hood I put a new bulb to replace
Burned out but did not light. Moved the other working bulb and that did not work either and when I put the working bulb back into the original socket it no longer worked either.
  • tlp1 Apr 22, 2009
    One bulb blew and my wife switched the good bulb to the other side. the bulb blew. I replaced both bulbs and only one side works now... the right side, the one that blew first. Any thoughts
  • tlp1 Apr 22, 2009
    I've got the same type of trouble. One bulb blew and my wife switched it out with the other bulb and that bulb blew. I replaced both bulbs and now only one side works... the right side, the one that blew first. any thoughts?
  • 10,865 Answers
Get two new bulbs and install them. These bulbs are exposed to a lot of heat above the stove and the filaments get brittle. I suspect that the filament on the bulb that still worked broke when you were screwing it out or back in. good luck. please rate my answer. thanks noreen.
Posted on Feb 03, 2009
Hey guys
These are halogen bulbs, so you must be very careful not to touch them with your bare hands. Use a paper towel, or even better latex gloves. The smallest bit of oil from your skin/ hands will cause the bulb to blow as soon as they get warm
Posted on Nov 25, 2009
Brake light failure
Bad circuit board tail light asseblise connector pin to board poor connection or burned push in light bulb sockets
On my '93 Chevy PU the new ones went bad within months I repaired the original ones by soldering all connector pins to the board cleaned the sockets chipping out melted plastic been working for five years now.
Care must be taken to keep solder from preventing wire connector install while using enough that plugging it in will not break these delicate unions.
Required pulling them several times to Finnish repair successfully.
Very disappointed in replacement parts.
Apr 22, 2016 | 1987 Toyota Celica
Installed new brake lights, now smelling burning plastic...?
I would say you have the incorrect bulbs in them.
Mar 11, 2017 | 1997 Toyota Camry
Break lights and blinkers not working
If you put the tester on the outlets and it lights up properly but the bulbs dont, you have already concluded that the wiring isn't the problem. unless of course the wires are corroded and simply putting the bulb in shorts it out. Have you tested the bulbs?
Jul 22, 2012 | 2008 Pontiac G6
2003 fire bolt low beam headlight problem
Sounds like you got a NEW BULB that was bad out of the box. happens. buy another.
Jul 01, 2012 | 2003 Buell Firebolt XB9R
2004 Chevy Impala lowbeam headlamp socket/connector burns--though bulb is fine. Replaced once already and now same socket has burned again--and the bulb is still okay. What gives?
Hi Miles, Have you replaced the head lamp bulbs and maybe used a higher output? That can overheat the fuses and or the connectors. The over heating and damage will usually be caused by loose connections causing high resistance and heating. Make sure the connections are tight. Regards John
Dec 12, 2011 | 2004 Chevrolet Impala
How can I replace the light on a allure range hood?
Sometimes they are hard to grab but dish washing gloves work well to get a grip.
Aug 29, 2010 | Broan-NuTone Allure II QS230SS Kitchen...
How do I unscrew bulbs to replace new ones??
I've not seen any range hood that used an unconventional socket so; counterclockwise.
Dec 18, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Kitchen Ranges Logo
1,363 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
