Question about Zebra Eltron P330i Card Printer
P330i will only print mono
How do I change it from printing mono. It worked in the past. Had to reload the driver and since then it only prints mono.
  • causeway0102 May 11, 2010
    Are you changing to color ribbon?
SOURCE: P330i card printer
Just a note, you need to be careful when sending the !SA command, as in some of the earlier firmware versions pre v1.16.11 , it can "double count" the i-series chip contained in the ribbon. So for example if you run the !SA command with a new ribbon with 200 prints remaining, it is possible after 100 prints the chip has counted down and the printer displays "OUT OF RIBBON" even though you have half a ribbon left.
I would use the following procedure to recalibrate the colour sensor only:-
1). Remove ribbon and lock the printhead down
2). Send the command !CSA_0 (Where "_" represents a space) - allow this stage to complete
3). Insert the ribbon and lock the printhead down.
4). Send the command !CSA_1 (Where "_" represents a space) - allow the calibration to complete.
This has works for me 99% of the time where the sensor array is faulty.
Posted on May 22, 2008
SOURCE: OVERLAPING OF COLOURS.
go to zebra and download the latest firmware and drivers (free).
update the firmware first
turn printer off
then uninstall (from uninstall programs) the zebra drivers.
then install latest zebra driver.
turn printer on
Double click on printer icon, click on properties.
Click on the device options tag, then click on the properties next to tools
Enter "CALB" and click execute - this will re-calibrate your ribbon
First try the CALB, if your current firmware does not recognize it, then you will
need to upgrade the firmware as above.
Posted on Nov 11, 2008
SOURCE: com.lexmark-commProblem-warning
try this. Some of the terminology may vary as I had the solution in german. It came from Lexmark.
Open
http://localhost:631
-     click add printer
-   enter a name for the printer eg Lexmark or troublemaker ;-)
-     click continue
-    from the list chose 'LPD/LPR Hostprinter' and click continue
-     in tne next window enter lexnet3://IP (of the printer):1
-     click continue
-     chose Lexmark and click continue
-     chose your printer type
-     click add printer
This worked for me after reinstalling the printer via cd software.
Otherwise try the usb cable, you then have to go to printer preferences and change the usb printer to standard.
Strangely enough my printer used to work fine via W-Lan, suddenly I received that error. Perhaps du to an update to 10.5.6? I don't know. Hope thet helps, best regards Peter
Posted on Jan 09, 2009
  • 63 Answers
SOURCE: zebra p330i just says downloading data
The reason in incorrectly established drivers, or in the printer. Better certainly to give to repair.
http://conditioner2009.bravehost.com/
Posted on Aug 08, 2009
SOURCE: Black will not prtint.
Brother printers are a low end product that only last a few months. When you have a problem like you describe, best option is to throw it away and buy an HP.
Posted on Dec 20, 2009
Error code OXC18A000A HP Officejet Pro X451dw
Hi
This type of behavior normally appears when printing out a "non-safe" font. Font usage is varied and there are fonts that are created just for viewing on web pages, as well as fonts that are best for printing. Often, these fonts will get used in the wrong place, or a developer will pick a font because they like it, not because it is safe for use in all the browsers.
I went to the link at sparkfun and printed it out with no problem, but I have the X576dw model of the OfficeJet Pro X series. I want to print to the X451dw like you have to see if I get the same issue.
When you copy/paste into Word, you essentially change the fonts. Word probably doesn't have the same font that is used in the web page.
Looking at the source for that site, they are using a font called "Roboto Slab" and sourced it from googleapis.com which is probably causing the issue. abcFileHippo Download Free Latest Update Software and Printer Drivers
Nov 05, 2016 | HP Officejet Pro X451DW Laser Printer -...
How do i get printing drivers for this machine
Dear
the driver may downloaded from the site on putting the model.
http://support.hp.com/us-en/drivers
Thanks.
Feb 15, 2015 | HP Deskjet 1510 Inkjet Multifunction...
Mac 0SX snow leopard 10.6.6 will not print also my local wifi system will not print, OS can not find /library/printers/lexmark/drivers/.resources/4900 series color 2.lut have reloaded driver from...
go to applications, utilities, and open terminal in the window, paste this: open /Library/Printers/Lexmark/Drivers/.Resources/ It will open the folder where the missing component should be. You will find the "4900 Series Color 1.lut" file. Duplicate it and change the name to 4900 Series Color 2.lut close the folder, and shoot a print, it should work.
Feb 07, 2011 | Lexmark X1290 All-in-one Inkjet Print...
P330i - The printer says Ready on the LCD but the computer reads Out of Paper? There are cards ready in the hopper?
please install the driver again, then send the command IM (print testcard)
If not work, Try to send !SA command and then try to print the card.
Oct 08, 2010 | Zebra P330i Thermal Card Printer
Printer doesn't recognise the color ribbon and print only in mono.
Try !SA command to calibrate ribon and printer, send command from the driver
Oct 07, 2010 | Zebra P330i Thermal Card Printer
My zebra card printer p330 i donbt recognized the colour ribbo YCMK, only detect the mono ribbon
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.
-- The Pros at www.DiscountIDStore.com
Sep 25, 2010 | Zebra P330i Thermal Card Printer
I've printed a test page, aligned the printhead, cleared the nozzles, and changed my black ink cartidge on my ESP3, but the printer will not print documents. The printer works during every test aand...
check the default printer when you print
the default printer should be the printer you want to print to.
when you print from like word you click on print then click on the printer tab box in the middle of the box.
Oct 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
ZEBRA PRINTER p4301
Try downloading the newest firmware/drivers (uninstall the old driver first - with the printer off).
and see if that helps.
Nov 11, 2008 | Zebra P330i Thermal Card Printer
Zebra Eltron P330i Card Printer Logo
681 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
