Question about Garmin GPSMAP 60Cx GPS Receiver
GPSMAP 60CX BACKLIGHT PROBLEM
I accidentally droped my GPS, and the backlight was gone. Have not been able to turn it on again. In the past, this has happended but by turning off, then on again the unit, the backlight will work again.
Sending the GPS to Garmin to replace a bulb for $125, is not a good option!
Any suggestions?
Thanks,
Jose R. Burset
  • Jose Burset Feb 09, 2009
    After asking Garmin for a solution, they have confirmed that the only option is sending the unit to them, costing $125, no matter what they do to fix the problem!!!
    I opened the unit and the bulb or led (I do not know what they use), is not accessible. Miraculously the light started working after almost a week without working.
2 Suggested Answers
SOURCE: Garmin GPSMAP 60Cx Powerup Problem
I suddenly had the same problem. Here a page with the explanations : http://forums.motionbased.com/smf/index.php?topic=3814.0 I removed the cache back to clean power connectors, tighten the cache back to properly adjust the power connectors on the map. Now everything is working properly.
Posted on Aug 05, 2008
justbob62
  • 30 Answers
SOURCE: gps was dropped now backlight won't come on.
The LCD screen has Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} separated at the lower end soon the LCD will go dark blue and need to be replsced
Posted on May 18, 2009
My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
When i turn on my gpsmap 60 cx it never acquires the satellites,it stays on this screen.
I had this on my Tom-Tom once. I think I reset it using the poke-a-pen-in reset switch, turned it off, charged it up with USB cable, updated it from the site, then went outside with it and it then finally acquired.
Jun 05, 2010 | Garmin GPSMAP 60Cx GPS Receiver
My Garmin gpsmap 60cx will not proceed past the welcome screen
I'd pull the microSD and see if it boots.
If so, reseat the microSD and see if it boots. If so, good. If not, try reformatting and loading the data back on.
Mar 09, 2010 | Garmin Gpsmap 60cx Handheld Gps
A stolen GPSMAP 60Cx is it posible to locate it once it is turned on???
Sorry, no. Report serial number and internal ID number(if known) to Garmin and the Police. If a map is ever unlocked for it or it comes in for repair at least Garmin will know.
May 07, 2009 | Garmin GPSMAP 60Cx GPS Receiver
My Garmin 60cx
my GPScxs will not aquire any satilights
Aug 14, 2008 | Garmin GPSMAP 60Cx GPS Receiver
Oct 31, 2007 | Garmin GPSMAP 60Cx GPS Receiver
Garmin GPSMAP 60Cx GPS Receiver Logo
70 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
