Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
02-03-09 Tues. 9:30am CST Hi Tech Help I have a DeWalt 1/4" Cordless Impact Driver DW056. It seems to slip when the trigger is engaged when loosening fasteners. I think the driver started impacting immediately when I first got it. How is the tool supposed to work? Thanks...Paul
Its supposed to impact immediately that is what gives the tool its power. once you get used to it you will use it for everything its lighter and more powerfull than the drill. just dont use spade bits in it or it will shatter them. try to buy tips that are impact ready
Posted on Feb 06, 2009
Want to change keyless chuck
If your wanting the sleeve, #12 on breakdown, then search the part # as There are other places that still have it. http://www.ereplacementparts.com/dewalt-dw056-type-18v-cordless-impact-driver-parts-c-1009_9591_2845.html
Nov 22, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Can you change just the bushes on a dewalt dw056
No, the brushes are part of the motor and pinion, Dewalt part number 607990-03. If you search "dewalt 607990-03" you can find several on-line vendors that sell the motor. They run about $50 plus shipping.
Jan 28, 2011 | Dewalt DW056 18 Volt Cordless Impact...
My impact driver is not this model its a dc827 but it quit hammering it just free wheels if you just slightly pull the trigger is kinda works is there anything i can do to fix this prolbem?
The pinion on front of motor is slipping on motor shaft. It seems to be just a press fit. Seems like a flaw in design. I had same problem. I took my dw056 apart and took pinion off motor and pressed groves into motor shaft with side cutter pliers. then pounded pinion back onto motor shaft. We will see how long this lasts the motor shaft is a softer metal. I feel the motor shaft should be hardened steel like the pinion and have a shear pin or some sort of spline to attach to pinion. Would like Dewalt to offer fix for this as I only used dw056 a couple of times before I had problem.
Jul 16, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Problem to work
Either brushes or trigger. I would check brushes first. Juraj
Jun 06, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Impact not working correctly
The pinion on front of motor is slipping on motor shaft. It seems to be just a press fit. Seems like a flaw in design. I had same problem. I took the dw056 apart and took pinion off motor and pressed groves into motor shaft with side cutter pliers. then pounded pinion back onto motor shaft. We will see how long this lasts the motor shaft is a softer metal. I feel the motor shaft should be hardened steel like the pinion and have a shear pin or some sort of spline to attach to pinion. Would like Dewalt to offer fix for this as I only used dw056 a couple of times before I had problem.
Jun 05, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Only full power for full trigger pull
I had same issue with Metabo hammer drill. It was faulty triggrer. Replace it and it shoul be fine.
Juraj
Jun 04, 2010 | Dewalt DW056 18 Volt Cordless Impact...
I have an 18 volt 1/2" drive cordless impact wrench made by DeWalt and when I pull the trigger the motor runs but not the anvil?
Sounds like you have a gear broke that runs from the motor to the shaft. Take it apart and check it out. easy to put back together. atleast you will know for sure and may fix it while it's opened up.
Jan 18, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Gear slipping in dewalt dw056
Those gears are only held on the motor with their tight fit, if yours is slipping that easily the motor will have to be replaced. The new motor will have that gear on it.
Apr 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt dw056 motor working but no drive.
make sure the selector switch is in full rev or full forward and not in mid throw goose the trigger and turn the selector at the same time
Dec 16, 2008 | Dewalt DW056K-2 18V Impact Driver
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
178 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
