Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
No digital only analog
What are the steps to get the tv to operate in digital mode. It is currently in analog. no one has been able to help me.
  • bingenito Feb 04, 2009
    cable with a digital box hooked to the tv.
    the tv source reads analog. I am missing channels I am suppose to be getting. Cable company says it is a Sharp matter. Somehow my TV is not operating digital.
  • Devon Sacco
    Devon Sacco May 11, 2010
    Are you using satellite, cable, or antennae?
    President:
  • 1,077 Answers
Ok,
1. Press MENU to display menu screen, and press c/d to select "setup".
2. Press a/b to select " CH setup", and press enter.
3. Press a/b to select "air/cable", and then press enter.
4. Press c/d to select "cable", and then press enter.
5. Press a/b to select "Analog & Digital Search Start", and then press enter
6. Press menu to exit after search is finished.
This should fix the problem. You'll have to repeat this steps to update the TV everytime the cable company changes the channels to digital.
Posted on Feb 05, 2009
WHERE IS THE RESET BUTTON ON MY TV
What is the brand name and model number of the TV. Can't say anything without these information. If the set is not too much older model, there will be no such button marked as "reset". For modern sets, if you have to do a reset, you should enter its service mode. It is somewhat skilled procedure.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 08, 2017 | Televison & Video
Toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 07, 2017 | Toshiba Televison & Video
Can I have the 4-digit code for the universal remote Sansai URC-501A to operate the panasonic TV tftv8157dt?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.....
Jan 06, 2017 | Panasonic Televison & Video
I have sound but no picture on my tv
This is a popular question. Most of the time you either need to make sure all connections are not loose or just need to turn off your tv and receiver and unplug. Wait for 1 minute then reboot.
I recommend this short video as it walks you through some diagnostics for other possible problems.
Repair TV With Sound But No Picture
Nov 24, 2015 | Luxor Televison & Video
I have checked cables and different methods of connecting, but the white and red audio out of my PVR appear to have stopped putting out sound.
Go through the setup of the PVR and check the sound settings. It sounds like it's only producing digital audio, that's why it works with HDMI but you want analog, so set the audio to stereo, or try every setting to see what works!
Jan 19, 2015 | Televison & Video
5 digit number for phillips tv
The 5-char Direct Philips Magnavox Universal Remote Code Entry is: PM335.
the Phillips tv (3 digit) code choices are: PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
Hope this helps! (Here's the link to same...)
Jul 09, 2014 | Televison & Video
Can't switch off tv
All tvs draw a current so long as they're plugged in, this is what allows a remote device to power them on. Modern tvs will generally have a light to designate this (I think this is what you're referring to as standby). The only way to cut the current to your tv would be to unplug it or if it's connected to a surge protector, switch that off.
Jun 28, 2014 | Televison & Video
How to disable mode from lg 55 inch smart tv 55ln5750
You missed the word demo, why repost?
On remote Press SMART (with house symbol)
go to
settings then
option then
mode setting then select
home use
(and, if you're feeling really brave, but it's not necessary to do this to remove demo mode
to return to initial settings
SMART
Settings
OPTION
Initial Setting
Deletes all optional settings and returns to initial default mode.
Once initialization is complete, the TV will turn off and on by itself.
If Lock System is activated, a pop-up password prompt will appear.
Do not turn off the power during initialization)
Jun 27, 2014 | Televison & Video
Can it be repaired and can I do it myself?
No, It's dangerous to repair a TV yourself, it contains hazardous electric currents. Most of such Electronic or Electric Gadgets have Hazard Warning on their Backside "CAUTION: NO USER SERVICEABLE PARTS INSIDE, RISK OF ELECTRIC SHOCK! DO NOT OPEN!!"
So, please consult Authorized Service Professional to repair your TV.
Apr 26, 2014 | Televison & Video
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
468 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
