Question about Westinghouse LCM-19v1 Monitor
Turns off after ONE second
I have a 19inch 1975NW.  I turned the monitor off last night and this morning I turned it back on and it stayed on for about ONE second then the screen went black.  The monitor was still "on" so I turned it off and on again and the same thing happened.  Can this be fixed or any suggestions?
  • 4 Answers
Like i put in another solution, this is probably the capacitors on the power board in the screen :)
easy fix if your okay with opening it and you can solder :)
theres 4-8 capacitors usually on the board, check if any have residue on them, or are fat (not normal cylinder)
Posted on Feb 05, 2009
We had a pwer outage last night and my comuter shutdown. This morning when I turned it back on the monitor will only stay on for about 15 seconds of inactivity before going into powersave mode. How do I...
The monitor goes to power save because no signal is coming from the computer - this means that the computer was fried by the power surge that caused the outage. To find out what was fried inside the computer you must open it and test its components one at a time, starting with the power source - time to take it to someone that has other parts to test it, or to an repair shop.
Apr 20, 2011 | Lenovo Computers & Internet
I have a westinghouse monitor L1916hw and my monitor was fine last night but this morn when I woke up the lighting was flickering and then went black and when I turned it off and back on it will stay lit...
Get in the habbit of turning off LCD monitors when not in use. First, save electric. Second, save your monitor as LCD will burn up faster than a CRT. As for your problem, I would assume it's burning out and/or about to burn out...overheating. I would shut the entire system down, let is sit for 5 minutes and reboot everything. If it still fails to strike properly, it is probably toast.
Jun 29, 2010 | Westinghouse Electric L1916HW 19" Monitor
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Samsung 206bw Monitor Flashes/Flickers on and off
Set the Hrts to 60 in Display Properties in control panel
Jan 14, 2009 | Samsung 206BW Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
Blank screen
Similar monitor, similar problem. I actually had to dismantle the thing and replace a transistor on the mainboard.
If you're not into soldering and such, good luck.
Oct 03, 2006 | Mag Innovision LT776s 17" LCD Monitor
Westinghouse LCM-19v1 Monitor Logo
145 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
