Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
No sound download from DCR-TRV27 Sony Mini
Plays back sound and video from camcorder. But will down download sound onto computer using USB cable.
  • scottsweeney Mar 18, 2009
    When I playback the recording on the actual camera, the sound is there. However, when I try to upload the video to my PC (for purposes of editting the video and burning it to DVD), the audio doesn't load.
    I am using MS Movie Maker, and a USB cable.
    Any ideas?
All I needed was the correct software for downloading video and sound. And that happens to be the software that came with the camera.
Thanks...
Posted on Feb 04, 2009
Want to downlaod to computer via usb, but computer doesn't see device
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Nov 11, 2010 | Sony Handycam DCR-TRV27 Mini DV Digital...
Can i download my video's onto my MAC?
Yes you can, you can use the Usb cable or you can use a memory card reader. Good luck.
May 15, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
Can not locate the driver for the sonyL15a digital handycam dv
General Information:
I understand that you're trying to transfer the videos from the Camcorder to the Computer using the USB Cable.
The USB Streaming of this Camcorder is not compatible with the Vista and Windows 7 Operating Systems.
However, you can transfer the videos to the Computer using the i.LINK(Firewire) cable or A/V Cable.
Feb 07, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
On the DCR-TRV27 I don't see a black roller on Error C:31:23 on Sony trv27
It probably fail off,which is very common problem, roller should be still inside of the camcorder. You also have to look for small white, lake tubing part that hold pinch roller on the shaft.
Nov 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
I JUST BOUGHT A USED SONY HANDYCAM DCR-TRV27 MINI
Congratulations! Please use the following link to download Manual, Operation Guide and other things.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRTRV27
Aug 14, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Windows won't recognize my sony dcr-trv19
Need a 1394 firewire port and suitable software like Corel Videostudio. Then no problems. When no 1394 port thoes pci cards come cheap, $15 or so. Video studio retails about $100 I think, you can download a free limited 30 day trial from Corel. Please uninstaal that demo after 30 days with the same install programm otherwise deep ****.
Jun 05, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony DCR-TRV27
i have (or probably had) the same problem. Try this - there is a small reset button on the left side panel of the camcorder. While the set is on VCR model press this and keep pressed for 30 seconds or so. The corrected image should return and probably the problem would go away. I tried this by chance and the problem doesn't seem to recur.
good luck.
I have another problem though:
In my Sony DCR-TRV27 - A part of the left side console buttons do not work - the tape controls (REW, FF, STOP, PAUSE, PLAY) work alright. The Memory Stick controls seem to work alright. But, pressing the Menu button does not bring any menu display on the screen. Similarly, the scrolling wheel on the front seems not working. A couple of years back the moisture went inside (I went to Niagara falls!). For few weeks whole of the panel wasn't working but now most of it works. But I cannot get the Menu option work. I would be glad to hear if you have any other suggestions / advises. thanks for your time,
Nov 06, 2007 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony DCRTRV27 Mini DVD video to CD ?
The DCRTRV27 can connect to a PC by using either a USB or firewire cable. If you want the best video use the firewire 4 to 6 pin cable. You can output the video as raw, then convert the video to any number of mpeg formats by using either Microsoft's Movie Maker 2.0, it's free, or the software that came with your camera. The video can be burned to CD, but this is not a very good choice since even the most modest video can easly exceed a gig in size.
Sep 13, 2005 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
156 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
