Question about Denon AVR-900 Receiver
DVR-900 blowing Fuse
The 6.3 A fuse on the power board keeps blowing. Any hints on where I should start to look to solve this problem?
  • 336 Answers
First check the output transistors for a short, 9 times out of 10 this is the case. Use a multi-meter on resistance. The transistors will have most of the part # on them, usually you just have to add 2S to the front example an "A1519" on the transistor would be a 2SA1519. If one is found to be bad replace it's complement also even if it checks good (unless you have a transistor checker that will check it for leakage). Good Luck.
Posted on Feb 03, 2009
My main fuse on 900 vulcan 2011 keeps blowing just when I try to put it in. Does anybody have any ideas? this bike has very ow miles and is kept in guarage.
Low battery will not blow a fuse. If it blows right away when you turn on the ignition you have a main electrical short. Disconnect the regulator to the battery connector at the regulator to see if you have a shorted regulator. After the main fuse blows you should not have a battery drain so figure out also why your battery is discharged. Is your batttery no good. This would not blow a fuse in any case. Was the battery out recently, or disconnected. Make sure it is installed correctly and none of the wires are connected incorrectly. THEN you will have to start tracing the wiring from the main fuse to find the short circut.
Sep 12, 2014 | 2011 kawasaki Vulcan 900 Classic LT
6 amp power board fuse blow when power button pressed.
That is usually caused by shorted output transistors. What brand/model do you have?
Apr 29, 2013 | Audio Players & Recorders
Ceramic fuse blows on power board
the power board is shorted and will need replacement. Yo can get the power supply board from www.tvrepairworld.com
Mar 16, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
No power or light, plus power supply keeps blowing fuse
you have a short most likely on the power supply but could be on the mainboard, inverter board, av/input board. The T-con board is fused and should blow its fuse before blowing the fuse on the power supply. I'm going with a faulty power supply, most likely a shorted Mosfet.
Sep 24, 2011 | Philips Magnavox 42MF521D/37 Television
Fuses keep blowing in tv
The tv have a short in many parts internally in tv power supply board itself could be anythings on the tv power supply board to causes the fuse to blow over and over again.U will never solved it if u don't have all the measuring elecronics equipments and skills and know how to find out.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 11, 2011 | iLO LCT32HA36 Television
The 5 amp fuse on the board keeps blowing the transformer smoked i replaced that but it still blows the fuse when i install a new fuse.the contactor buzzes then the fuse blows.
You ahve a short in the low voltage system, thats why the fuse blows and the transformer burned out. Find the short and then replace that fuse and that should solve your problem.
Jun 28, 2011 | Heating & Cooling
Treadmill keeps blowing fuse
I can't solve your problem cause I am haveing the same, But i lost my fuse on the way to get a new one can you tell me what the fuse is? Volts? MA? All that?
Jun 14, 2010 | Exercise & Fitness
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Blowing fuses in power supply
One thing to check, would be the filter capacitator that is on the front circuit board. They are known to become shorted. The cap is fairly large, and may be mounted on the side of the circuit board that faces the front panel. Clip one lead, and apply power. If the fuse does not blow, then that is it. A second possible component, is the polarity protection diode, that is near the power jack, next to the fuse. If it is shorted, then the fuse will blow every time.
Aug 21, 2008 | Optics
Have a kenwood kac849 600w amp keep blowing fuse on amp as soon as power is too it power wire got wet and now this can i bypass that fuse some how
It would be very dangerous to bypass a fuse. If it keeps blowing, bypassing the fuse will only create lots of internal damage and maybe a fire as well. The fuse is blowing for a reason, the amplifier is not going to somehow start working because you bypassed the fuse. You also need to stop trying to turn it on, every time it blows the fuse, it keeps stressing the components inside. You have a shorted power supply, probably water damage as well since the power wire got wet.
I repair car amplifiers for a living, and can tell you with all honesty that bypassing the fuse would be a terrible mistake to make, the amplifier would end up being un-fixable with holes burned right into the board.
Please, just take it in for service or get a new amplifier. That is the only sensible thing to do. The amp will not start working bypassing the fuse, it will only start smoking.
Jul 10, 2008 | Kenwood Car Audio & Video
231 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
